![]() Join Date: Sep 2017
1969 C20 front shock question
FWIW this might be worth moving to the 'stupid question' section if there is one...
I searched the forums and the internet in general but couldn't find an easy answer... Checked LMC diagrams and images and can't find this bolt. It is supposed to be holding the shock to the frame, i assume... i got under the truck and noticed the drivers side is not connected at the top... based on the passenger side, it doesn't look like there is a bracket, just bolted to the frame. Is this bolt available and just not in the shock section of catalogs/websites? When I ordered replacement shocks, they each only come with one bolt? are the top and bottom bolts the same? are they to be reused? is there a missing part where the frame is that the shock should bolt to? TIA! ![]() |
Re: 1969 C20 front shock question
forgot to attach picture. looks like its upside down. fail!
![]() Join Date: Feb 2019
Bolt should come with the shock.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
better pic... i think...
but only one, so the idea is to always reuse the lower bolt? why wouldn't they just give you another bolt? seems like you'd want to replace both bolts with the shocks...
based on the pics, it looks like it came out of the frame but the nuts are still on the bolt... is that even possible? |
At the body shop.
Also known as a P-19 pin
" That didnt make it any newer " " Dont antique the equipment " |
#7 | |
![]() Join Date: Feb 2016
To see the condition mine was in, use the link and scroll to post 165. https://67-72chevytrucks.com/vboard/...=698377&page=7
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I've bought the bolt before. Forget where I got it from. On my 89, I used a regular bolt from Home Depot.
bolt head - washer - frame - washer - nut - washer - shock - washer - nut
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
![]() Join Date: Nov 2018
Looks like you need new shocks anyway. The bottom bolt can be sourced at any hardware store. If any help I think this same configuration was used up until 87
At the body shop.
If your frame is worn or cracked enough for a new shock bolt.
I got these off a later model K series truck with factory dual shocks.
If Kilroys or Reibes can't help you out, I got this one you can have. Not sure if it came off the 20 or 10 or if that even matters. I'll check back this evening.
#12 | |
Thanks! |
