![]() Join Date: Apr 2000
71 k 20 body mounts issues
Can anyone measure there 71 or 72 k20 body mounts for me? I bought new mounts and now the front is too low and the master cly. is hitting my upper alt. braket. Just need to see if i have the right ones (suppose to be 71-72 4x4) before i start shimming the cab. thanks
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 71 k 20 body mounts issues
Are you sure you don't have a half ton frame? Half ton had shorter rear cab bushings.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
no i got the 3/4 the cab is low in front
All about them K’s
![]() Join Date: Jun 2014
Can you post pictures of what you’ve got right now? I can measure my mounts in the morning.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
I got the lmc, full mount kit,its for the 4x4s from what i read they run short, from stock I think i`m about 1/4 low in the from and 1/2 in the back from compairing to a friends pic he sent off his truck.
#6 | |
The busing kit is different on half ton 4x4 and 3/4 ton 4x4. I have seen this mistake more than once.
#8 | |
![]() Join Date: Dec 1999
That is your problem right there. Look at my truck in my build thread. Pics before I tore it down. Cab is low in back, was that way when I installed the LMC mounts. The new ones I put in are from Classic Heartbeat. Actually ended up a little high in the back. Did not have rear cab bushings seated in frame mount. Should be right on when I re-assemble.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
this kit is for a 3/4 ton 4x4
#10 | |
All about them K’s
I’m certain longbed K10 and K20 use the Same identical frame model year for model year. With that said bushings shouldn’t make a difference on a long bed 4x4, whether It’s a K10 or a K20. I’ll know know more about the short K10 bushings tomorrow. I’d bet your issue is LMC as well.
after adding 2 more shims to the front and 3 to the rear , the mounts are the same height as what i took out,so lesson learned,don`t buy mounts from lmc..
The easy way to remember how cab mounts work between the two sizes is C/10s have unique rear cab mounts. They are shorter which means the mount sits higher on the frame. All 20 & 30 series trucks and all k-models take the other mounts. So it can be kept simple with just remembering C/10 is unique, everything else the same
I can't believe they can't even have simple pieces of rubber made to the right measurement. It's not a 1/16" either. Not even close. Are they even trying to get it right? ![]()
