Old 04-10-2020, 09:21 PM   #1
dtkarst
Just picked up an 85
Just picked up the newest squarebody I’ve had to date. 1985 Silverado 3/4 ton camper special with a factory 454 and 4 speed. It was only about 15 miles from me and the guy said he parked it because he thought the clutch was going out. Anyway got it home today, threw some fuel on the passenger side tank and started cranking and she fired up. Runs smooth and the clutch actually works fine. But if anyone can help me with this I’d appreciate it, the front brakes were really tight at first and I cracked each line and they released. So I drove it and after using the brakes a couple times they got really tight again but release if I crack the line. So would that be an issue in the proportioning valve? Or in the calipers? If anyone has a clue let me know, but I think the brakes got tight on him and maybe got hot and it wouldn’t move so he assumed the clutch was out. Anyway here it is, been repainted white at one point from what I can tell.
dtkarst is offline   Reply With Quote
Old 04-10-2020, 09:23 PM   #2
dtkarst
Re: Just picked up an 85
And the spid. Has all four original whee covers but I think I’ll go with the dog dish like in one of the pictures
Old 04-11-2020, 04:24 AM   #3
wildwilly4x4
Take the calipers off and lube the slides. Also may be a good time to go ahead and put new pads on....just to make sure that the pistons aren't coming too far out of their bores. It's possible that the combination valve has too much residual back pressure from being dirty/ stuck. Maybe flush out the system with all fresh fluid before tossing parts at it. My $0.02
wildwilly4x4 is offline   Reply With Quote
Old 04-11-2020, 07:56 AM   #4
Big Chip
Big Chip's Avatar
I would replace the rubber lines while you were in there just to make sure they aren't collapsing and holding pressure at the caliper.
Big Chip is offline   Reply With Quote
Old 04-11-2020, 07:57 AM   #5
DoubleDubya
It could be your brake hoses. They are known to deteriorate inside and not let the fluid return to the reservoir. I'd try that first.
DoubleDubya is offline   Reply With Quote
Old 04-11-2020, 09:18 AM   #6
peabobble
X2, brake hoses.
peabobble is offline   Reply With Quote
Old 04-11-2020, 11:06 AM   #7
Hart_Rod
Hart_Rod's Avatar
Nice truck! X3 on above.
Hart_Rod is offline   Reply With Quote
Old 04-12-2020, 01:53 PM   #8
SCOTI
SCOTI's Avatar
x4. Replace the brake hoses. Lube the caliper pins while doing the brake service.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-12-2020, 05:01 PM   #9
dtkarst
I’ll try out the rubber brakes lines and spraying down the calipers. If not they’re not too expensive to replace
Old 04-12-2020, 05:03 PM   #10
1976gmc20
And remember these old pickups do not have sealed front wheel bearings.
So while you're in there, might want to think about re-packing.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 04-12-2020, 06:51 PM   #11
SCOTI
SCOTI's Avatar
Truth. I didn't think to mention that but I've never owned a vehile w/sealed bearings.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-12-2020, 09:07 PM   #12
1976gmc20
Yeah, and there's probably younger folks on here saying: "Re-pack wheel bearings? WTF does that mean?"
Back in my service station days, re-packing wheel bearings was a big part of our business. Also an essential part of replacing front drum brakes.
Old 05-06-2020, 09:01 PM   #13
dtkarst
I replaced the old rubber brake lines and they fronts no longer stay locked up but I bled them once and the pedal feels soft but it’s stopping it. Tried bleeding them again with no change but when I hit the brake pedal and push it down almost to the bottom the brake light comes in. Still a little spongey for my liking so would the next step be the proportioning valve?
Old 05-06-2020, 09:56 PM   #14
v30crewcab
v30crewcab's Avatar
sounds like the proportioning valve got off center. need to bleed the front and rear again and get all the air out, and hope it will recenter by itself.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
