Trans cover??????
My cab has a high hump tran. cover.
will a low hump (the FLAT looking one) fit in there and bolt holes line up.?? There is plenty of room for my motor and Trans. to fit. Is that high hump for a 4 wheel drive Trans.????? My Cab is a 4B cab, I think that is a 1-1/2 ton cab? Thanks |
Re: Trans cover??????
It seems like most of the carpet kit's are for low hump??
In my 3100 the flat cover replaced the humped cover, no problem...
![]() Join Date: Jul 2007
High hump was to clear the 4 speed if it has the hole in it for the shifter.
I'm not understanding the 4 B thing, can you explain on that? Chevy or GMC? The flat trans cover should bolt right in though.
I Can't find it right now but I ran accrose it before.
I THINK ? On the vin. tag 2B is a 1/2 ton 3B is a 1 ton 4B is a 1-1/2 ton I THINK all the cabs are the same but it was just the tag on the truck that was different? Edit---- I found some info HERE https://chevytrucks.org/1956-chevy-b...k-vin-decoder/ TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT Last edited by MD2020; 05-08-2020 at 07:58 PM. |
as mr48 stated the high hump is for the 4 speed granny tranny
if you still have the motor in stock location a car 3 or 4 speed will fit with low cover any modification will be hit or miss, truk has 700r4, i had to slightly modify the low cover
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I have a custom frame and plenty of room under there.
I just wanted to know if it would bolt up to the original holes. Thanks for the info, and I ordered the low hump (flat one). |
![]() Join Date: Oct 2011
Yes, the flat will bolt up to the same holes. I removed mine with the hump and installed the flat. The new flat was fiberglass and not steel. Not sure a steel is offered.
Thanks Mike
I found both when looking for a replacement and opted for steel...
![]() ![]() Join Date: Nov 2008
My truck HAD the flat cover. I have a 4l85e behind my LQ4 and it wouldn't fit unless I put the humped trans cover on it.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
