![]() Join Date: Aug 2018
1969 to 1972 gauges cleaned up and painted bezel
Gauges are original and the speedo was taken apart and cleaned and miles set to zero. All other gauges are in good shape. The bezel has been repaired where someone had a hole drilled in it and was repaired at one point. Good set of gauges for a driver. $100.00 shipped to the conus.
Re: 1969 to 1972 gauges cleaned up and painted bezel
The bezel also has a small hole drilled beside the speedometer
![]() Join Date: Oct 2012
Hello. Does this gauge cluster work properly? Thanks in advance, Clark.
Yes, all gauges work. No longer available
