Anyone flip '60-'66 bumpers?
We all know they look like they're upside down...
Has anyone flipped a '60-'66 front or rear bumber? (rear on the Suburban only, I guess.) I've thought about it, but am not sure the contour of the bumper will fit properly along the sheet metal. Cutting the frame mounts off and flipping them will be easy enough, the question is will the factory bottom edge of the bumper wrap around the grill surround panel and front fenders neatly? -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Re: Anyone flip '60-'66 bumpers?
Here's mine.
C/10 junkie
I really like that!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
What kind of fabrication did you have to do to the front brackets?
Hmm,now that's different I always thought they looked upside down to.Thanks for sharing.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
Cut and flipped the frame horns. Took an inch of meat off the bottom(now top) of the bumper(thin steel aftermarket). For the rears, I reused and cut and modified the outer brackets, and the inners were fabbed out of two inch strapping. Like everything, lots of cutting, fabbing, eyeballing, and welding.
I really like the front bumper
65 short step edited by staff |
Zero Albedo
That flipped front bumper looks good
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
![]() Join Date: May 2007
73sd that looks really good!
Kinda makes it look Fordish.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
But Found Her 25yrs Later!
Mine,
Both Front & Rear ![]() ![]() Posted via Mobile Device
#12 | |
Drives my wife nuts that I make stuff up as I go along. Love the rears flipped. Posted via Mobile Device |
Got my degree in eyeballing from NTSU, now UNT. Back then they called it industrial technology. We actually learned how to stick weld, draft with a #2 pencil, use Sun distributor machine to dial in my Transam, and rebuild Briggs and Stratton engines. My last year they brought in Cad/cam lathes and a cnc milling machine. They the the Bridports in the trash. That was in '88.
Btw, wasn't worried about the frame horns, since they were grafted to a '71 frame. It does look kinda Fordish, like The first Galaxies in the Andy Griffith show. I'm putting a 65 grill back on it. Posted via Mobile Device |
![]() Join Date: Jan 2012
Here's mine I flipped the front bumper and mover it in closer to the body.
I cut the front frame mounts flipped them over and made an offset in them to slid into the fram rails and bolted them in. I also welded some extra metal on to them for some extra bolts. Also made some mounts on the outter bolt holes that bolt to the inner fenders. ![]() ![]() Drivers side. I cut an angle on the bumper to match the wheel opening. ![]() Passenger side. ![]() Hope everyone has a great New Year. ![]()
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
#15 | |
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#16 |
Thanks guys! Definitely going to flip mine--at least the front one.
I'll have to look to see what's involved in flipping the rear on my Suburban. I'm concerned that the way the ends wrap around, it'll crash into the quarters. New high-quality repro front bumper, made of original gauge steel, and I had the rear bumper straightened and rechromed, so I don't like the idea of cutting on them. -Brad
#17 |
Just thought of doing this to my '66 GMC. I like the look, front and back..
