Old 06-11-2020, 10:14 PM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
1986 dash clock wire question
hi,
I am in the middle of a LS swap in my '86. My question is about the wire conn. to the instr. cluster dash clock. I am wanting to know what the electrical properties of the orange wire is. I think (?) that it is a constant power on wire from the fuse block? ..is this right? I would like to re purpose it once I know what the power properties are for it..... excuse my lack of correct electrical terms... !!!
moderators please feel free to move this if deemed not in the right forum.
thanks!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 06-12-2020, 05:16 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 1986 dash clock wire question
It is constant. What are you trying to re-purpose it for?
Hart_Rod is offline   Reply With Quote
Old 06-13-2020, 06:56 PM   #3
rodstored-72
chevy truck fan
Rob, thanks for the reply, I am looking for a key on acc power wire to connect the V.A. AC to.?
Old 06-13-2020, 08:14 PM   #4
Axle
Axle's Avatar
If you look at the fuse block, 2nd row from the top (well, kinda sorta, double check with a volt meter) you'll see a cavity with a connector deep down (an uninsulated 1/4" male spade terminal will fit right in there, just make sure you put it between the fingers) labeled ACCY. That'll be a switched 12volt point.
Another handy spot, 12volt switched line off the radio harness. Just be mindfull of current draw of what you are adding.
Alex.
Axle is offline   Reply With Quote
Old 06-14-2020, 10:36 AM   #5
rodstored-72
chevy truck fan
Alex (Axle),
thanks!! I will do that. it would be nice to be able to just connect to the cab fuse box...
