![]() Join Date: Jun 2010
Sport mirror mounting screws
Do sport mirrors use sheet metal screws to go through the backing plate? I bought a set of repop sport mirrors and was surprised that there were not threaded holes in the backing plate. It comes with sheet metal screws that go into the backing plate.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: Sport mirror mounting screws
No, was not a sheet metal screw. It is GM part number 9419728. It is a 14-20X7/8, stainless steel screw. GM used this fastener on many cars in many places in the 60s & 70's. They can be found on fleabay. The new old stock backing plate have the threads, the repops do not.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 06-20-2020 at 02:45 PM. |
Not my pic but does it look like this style
the stock ones on my 68 had threaded backing plates Lmc does show there backing plate for this style are threaded Not sure about the smaller mirrors i have seen on our trucks Other way is to drill holes and tack nuts on your backing plates Last edited by gmc684x4; 06-20-2020 at 02:48 PM. |
Just buy the proper screws and retap the backing plate to accept the screw.
71 C-20 07 Magnum RT AWD |
#5 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#6 | |
![]() ![]() Join Date: Feb 2009
Discovered those screws your showing had two different types of heads. Philips and I can't remember if it's a star or alan, but I'm pretty sure they take an alan wrench (Correction, Torx head). Otherwise they're the same screw, stainless steel. Guy I got them from thinks the phillips head came later. (Correction - Torx followed Philips) )
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-21-2020 at 06:20 PM. |
My 68 truck stock mirrors are Philips head machine bolts like pictured
i would have to look as a young fella when the glass fell out off roading I took them off looking into a hot rod build what was my original intention for the 68 low and fast broke young guy i was I got into 4x4ing and made her into a 4x4 |
Come to think of it, by the looks of the backing plate in post 2 there were at least two types of threaded nuts as well. Those are posts for lack of a better description, the nuts on my plates are square.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Dec 1999
Have a pair of GM backing plates that look the ones in post 2 post by Lee H. I purchased around the year 2000 from a local dealer. Punched with a machine thread. They are GM, still have the labels on them. I think the original design had nuts welded on though. Have seen them. Purchased stainless torx screws to mount my mirrors. Torx would have never been used that far back. Aftermarket backing plates I have seen are punched for a sheet metal screw. Like the speed clips on dash, instrument panel etc.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
The backing plates where still attached to my 71 GMC even though the sport mirrors removed for West Coast JR’s. Both have captured nuts fitted to them. The plates are original equipment to vehicle.
#11 | |
And I agree, the original was a square nut welded on the plate, same style as the fixed nuts you find for body bolts. I have (had?) NOS plates with the stickers still on for a tap screw. Part number 6263291-2. Found a website that shows three part numbers (two replacements), 6263291 is the later version (July 1972).
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-21-2020 at 06:44 PM. |
Here is a reply from GMC Paul's to my question:
Hi, John All of the reproduction 1970-72 sport mirrors use the 3rd and final version of GM backing plate that was made that uses sheet metal screws instead of machine screws. There are still some NOS GM mirror backing plates floating around that uses the machine screws, but be aware there are also 2 different versions of these, the 1st version they welded a nut to mirror bracket or pressed it into place and tacked welded it also, the other version they pressed the metal hole opening slightly small and then made machine screw threads in the distorted raised metal from punching the hole. The 2nd version is known for having the bracket threads distort and strip out easily. So if you look to locate NOS mirror brackets I strongly suggest you get the captured / welded nut version. Hope this helps. Thanks for your interest and We Hope 2020 finds you Blessed with Health, Happiness & Prosperity and will continue to find you so! My Best Regards Sky @ GMCPauls
Carpe manana
![]() ![]() Join Date: Dec 2010
The NOS mirrors on my Blazer came w sheet metal screws and the instructions were dated 1971 - interestingly, the instructs were for a "G"series truck.
Here's an example photo of the screws (period NOS) I used and the (later run NOS) backing plates I used: https://67-72chevytrucks.com/vboard/...94&postcount=2 Either screws or bolts are probably correct
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 06-22-2020 at 07:44 PM. Reason: clarified |
Great information, thanks for posting GMCPaul’s response.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#15 |
good info on mirrors, thanks
#16 |
Sometimes we go pretty deep on stuff, it's pretty cool. Keep it up we'll be Mopar Nerds
![]() I've been through a lot of cars, but only one Mopar, 75 Dart. Fun car I guess, only a 318. Sounded like a jet plane warming up. Ten minutes to warm up too, otherwise it would die on me. Without knowing much about them, if I could choose a car it would be a Mopar, the car in this picture would suit me fine. Personally I'm so-so vintage Chevy passenger cars, much rather a Pontiac. It's just that vintage Chevy trucks are best ![]()
