Old 08-07-2020, 03:23 PM   #1
70inbville
steering gear help
Hello all,
Will the steering gear from an 87 r10 bolt up to and work on a 74 K20 frame?
Thanks,
Chip
70inbville is offline   Reply With Quote
Old 08-07-2020, 06:49 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: steering gear help
It should, the main differences will be that the later unit will likely be a quick ratio box(not a bad thing) and also the later box will have metric power steering hose fittings, that’s easy to overcome though.
Tyler
Old 08-07-2020, 11:50 PM   #3
70inbville
Thanks for the help!
Old 08-08-2020, 01:34 AM   #4
57taskforce
All about them K’s
I had a major brain fart on this one, It just hit me that the R is the 2wd and V is 4x4 if I’m not mistaken. If you’ve got a 2wd box it will not work with a K series truck because the pitman arm moves side to side as opposed to forward and back. I apologize for missing the boat on this one.
Tyler
Old 08-08-2020, 02:29 AM   #5
Richard
Something new learned. 87 R10 2wd, last year of the square body's. You could use it with a crossover steering conversion.
Richard
Old 08-08-2020, 08:44 AM   #6
70inbville
Well r or v it is a 87 1/2 ton 4wd box going on a 74 3/4 4wd frame if that helps. i have thought r was 4wd huh i learned something today as well.
Old 08-08-2020, 09:18 AM   #7
57taskforce
All about them K’s
Ok then if it’s from a 4x4 truck my original post stands!
Tyler
Old 08-08-2020, 09:28 AM   #8
70inbville
thanks again! I've been searching part numbers and have come to the conclusion that it will fit and the number differences probably have to do with the metric connections. I am swapping the eng/trans/ tc, fuel tanks and associated stuff as much as I can from the 87 into the 74 k20. keeping it a 3/4 ton. its a long story that I'll so a build thread someday to explain it all
Old 08-08-2020, 10:12 AM   #9
57taskforce
All about them K’s
Sounds good I look forward to seeing progress.
Tyler
