![]() Join Date: Mar 2012
bench seat thought
Guys,
just wanted to run this by you guys . I am thinking of using some 1 x 5 rectangular tubing to use as a shim/ spacer to raise my seat an inch to allow for more room for speakers underneath. and instead of using the the standard bolts going with a stud and washer/nut
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
