Old 10-05-2021, 06:09 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Brake push rod assembly lube?
My instinct says these should be lubed. I used brake grease for the pedal sleeve/shaft, but that might attract too much dirt under the hood. I think graphite may have a place here, though I'm not sure they were even lubricated.
These are for power brakes (71ish), not sure what manual looks like....Thanks.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-07-2021, 12:34 AM   #2
71CHEVYSHORTBED402
Re: Brake push rod assembly lube?
For what worth, per the assem. manual the area is not lubed.
Tony
Old 10-07-2021, 08:36 AM   #3
sick472
sick472's Avatar
I've redone a few vehicles and have never lubed these parts...no issues. If you want to lube it, graphite would be the way to go every few months depending on how often it's driven/washed etc.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 10-07-2021, 02:10 PM   #4
71CHEVYSHORTBED402
Thank you
Tony
