Old 10-05-2020, 11:36 PM   #1
HO455
HO455's Avatar
Why RTV sealant is bad!
I pulled this engine apart yesterday and found this. From the outside I noticed the blue goo oozing from every joint around the timing cover. Photos 1 and 2. Photo #2 has blue lines pointing to the over application of RTV. When I pulled the head photo 3 shows the RTV that was inside of the water passage. The 4th photo shows the total length of the RTV that was in the passage. It is obvious that there was little to no water flow to number one cylinder.
RTV sealant must be use with discretion. Too much can be damaging. The is a reason that manufacturers like CAT no longer use RTV sealants. They now use the more expensive Anaerobic type sealants to prevent to prevent this kind of problem.
RIP Bob Parks.
Old 10-05-2020, 11:43 PM   #2
Re: Why RTV sealant is bad!
I think the problem is 'misusing' RTV, not using. Too heavy an application I have known to be bad for many years. It's a good thing when used right. I never used it all that much, but it has it's good uses.
Old 10-06-2020, 09:48 AM   #3
Sheepdip
Sheepdip's Avatar
I guess I'm still old fashion as I still use gaskets with a very light film of RTV to fill any voids.
A few years back before the internet I went to a parts house for a couple of front/rear differential gaskets for my 46 CJ2A, I was told #1 "we don't have those" and #2 "everyone just uses silicone"....not me, I eventually got my gaskets.
Sheepdip is offline   Reply With Quote
Old 10-06-2020, 12:19 PM   #4
truckster
truckster's Avatar
I only use RTV where necessary. I prefer to use gaskets with a light coating of Permatex Aviation Form-A-Gasket on both surfaces.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-06-2020, 12:25 PM   #5
Killer Bee
Killer Bee's Avatar
there isn't a sbc on the planet that won't leak somewhere without rtv
Old 10-06-2020, 12:53 PM   #6
bhemingson
Don't blame the gun - blame the gunner. RTV in the appropriate amount is ok
bhemingson is offline   Reply With Quote
Old 10-06-2020, 01:18 PM   #7
i82much
Hogwash! I love it so much I use Ultra Copper as toothpaste!
i82much is offline   Reply With Quote
Old 10-06-2020, 02:47 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Many years ago I had a '75 Dodge Coronet that I got really cheap. It jumped time so I bought the gears and chain only. Cleaned the mating surfaces and used Permatex Aviation Form-A-Gasket and no gasket! My neighbor was going nuts, not believing that it would seal. I'd hate to be the person who had to pull it apart later, though.
~Steven
Simi Valley, CA
Old 10-06-2020, 08:49 PM   #9
Intake valley gaskets at the ends and oil pain gasket at the main seals. A little dab'll do ya... ey?
I get what HO455 is saying about excess RTV "internal ooze". Button the thing up and that's the part you don't see and it can cause some serious issues. This is why RTV "can be" bad
Old 10-06-2020, 10:07 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
I remember an old story (I think in Hot Rod Magazine) about some team losing a drag race because the carb had a chunk of RTV in it. I don't let stuff like that get anywhere near the fuel system. I wonder how that happened?
~Steven
Simi Valley, CA
Old 10-06-2020, 10:33 PM   #11
jimijam00
NOTHING wrong with RTV.
jimijam00 is offline   Reply With Quote
Old 10-06-2020, 11:52 PM   #12
Sheepdip
Sheepdip's Avatar
I bought a used but looked brand new 600 Holley on craigslist for a $100 bucks, the guy said he ran it about 100 mi and decided to go with a different carb......found out the real reason why.
Got it up and running and had problems right away, pulled the front bowl off and it was full of RTV bits, of course plugging the jets and whatever else.
I thought how in the sam hell did that get in the fuel system. It appeared that the carb had not been separated and no sign of RTV on the bowl gaskets.
Got a gasket kit cleaned it all out still runs perfect today. One of those mystery's.
Old 10-07-2020, 01:08 PM   #13
Orange Crate
Orange Crate's Avatar
Everyone is missing the point of HO455s post! There is something BETTER than RTV.
HO455 please tell us about the newest Anaerobic sealants. Product names part numbers where we can get it...
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is online now   Reply With Quote
Old 10-07-2020, 01:13 PM   #14
weq92f
weq92f's Avatar
Gaskets + Gasgacinch!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-07-2020, 02:48 PM   #15
Killer Bee
Killer Bee's Avatar
no - they are two different product categories used for different applications..
the proper use of each is the path to success
THE TEN MOST COMMON GASKETING MISTAKES
6. Trying to fill a large gap with an anaerobic gasket maker.
Anaerobic gasket makers and flange sealants are designed for sealing assemblies where two close fitting machined metal surfaces come together. They’re generally recommended for gaps of up to 15 to 20 thousandths of an inch only. If you’ve got larger gaps – such as sealing a stamped steel oil pan, you should be using an RTV gasket maker.
what you may not understand is that anaerobic sealants will stand in open containers for years and never cure until applied where isolated from oxygen.. loctite thread lockers are a perfect example of this, they'll sit without caps for years and still be liquid..
rtv products work much differently, they react to the moisture in the air which initiates curing process.. they are also a type of anaerobic as they continue to cure internally where oxygen is not present.. that is why a slightly used tube of rtv will be cured to the seam with a year or two after opening..
there are hundreds of these types of products out there.. best practice is to become more familiar with the process you're working with and apply the proper sealing technique and sealants to the job..
happy sealing!
Old 10-07-2020, 04:48 PM   #16
Boog
laying low
Boog's Avatar
Way back in the 80s the company mechanic ( and I use that term oh so generously ) kept the trucks running, in and out of the shop mostly. My truck had no heat. He yanked a heater hose off at the firewall and there was a blue strip of silicone. He pulled it out and it was almost 12" long. NO WONDER I had no heat!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-07-2020, 05:00 PM   #17
garyd1961
If you use the right stuff in the right places there is nothing wrong with it. Just rebuilt a Toyota 22re and the pan gasket is still laying on the workbench. The gasket will leak long before the FIPG gasket maker will. Lots of auto manufacturers recommend gasket makers in a tube over regular gaskets nowadays.
garyd1961 is offline   Reply With Quote
Old 10-07-2020, 07:45 PM   #18
72c20customcamper
72c20customcamper's Avatar
Right stuff is the #### I put the hashtags in . Use a little and it pretty much will outlast the part
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-07-2020, 07:58 PM   #19
Killer Bee
Killer Bee's Avatar
we're captured fleet here.. this is what uncooperative drivers get from my guys
not directed at you Boog but your story reminded me of it
Old 10-07-2020, 10:28 PM   #20
CastIron
CastIron's Avatar
When you say the right stuff are you talking about the sealant called the "right stuff"? I've used that many times and it does work great. I've also used Toyota FIPG many, many times and it works great as well.
CastIron is offline   Reply With Quote
Old 10-08-2020, 09:23 AM   #21
Peanut74
This thread has some good examples of how the "the more the better" philosophy is bad. I do use sealant but as stated by others just enough to do the job IE: small 1/8" to 1/4" diameter beads. For the high temp I use spray on to make sure I get a seal and to make sure I don't over apply the sealant.
I was taught by my dad who permatexed everything. Old habits die hard..
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 10-08-2020, 04:03 PM   #22
Jblackie47803
I've read about people cracking intake manifolds they tried to remove after being sealed on with The Right Stuff.
Jblackie47803 is offline   Reply With Quote
Old 10-08-2020, 09:18 PM   #23
garyd1961
I should have phrased that differently. I do know about the "Right Stuff" but I was referring to using the right type of sealant/gasket maker. There are different types for different applications.
Use the right amount of the correct sealant and you shouldn't have a problem. There are some applications though where using the correct gasket without sealant is best. Certain intake gaskets already have a bead of sealer where needed and should be applied dry. The same for head gaskets.
Old 10-09-2020, 02:06 PM   #24
bry593
True that!!!
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
