Old 10-24-2020, 09:40 PM   #1
cff
66 K30 Front Diff
I'm going to make a K30 out of my C30. Any recommendations on which diff to use? I want a dana 60 with power disc brakes and am hoping to not have to narrow it to make my tires fit underneath comfortably. Any info would be appreciated.
cff is offline   Reply With Quote
Old 10-25-2020, 02:16 AM   #2
franken
Re: 66 K30 Front Diff
I think the early 60s trucks were very similar to 67-72 regarding the frame and WMS stuff. WMS means wheel mounting surface or the distance from where a wheel mounts to the other. Measure from rear drum face to the other to start. Look for a front diff w/ the same/close dimensions. The new diff has to have the same ratios as the rear.
73 and up fronts are supposed to be a bolt in for 67-72 but since you're 2x4 you need the frame mounts. The crossmember on a 4x4 is different.
Needless to say you need a TC and cut/new rear driveshaft and one for the front.
Power brakes has little to do with the conversion...
Old 10-25-2020, 10:59 AM   #3
cff
Thanks. I'll start watching and measuring
the newer front ends
