Old 10-21-2020, 08:08 PM   #1
pjmoreland
pjmoreland's Avatar
Bench Seat Identification
I'm trying to figure out what year the seat in my truck is from. The tracks appear to be the 69-70 style. The previous owner told me the seat itself was from a 66. Does that sound right? The reason I ask is because it seems extra tall compared to the seats in the other three C10s I've owned. I have to hunch down to see stoplights, and the steering wheel blocks my view of the speedometer. Also, there is very little room between the seat and the bottom of the steering wheel.
pjmoreland is offline   Reply With Quote
Old 10-21-2020, 09:21 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Bench Seat Identification
Extra padding was definitely added to the lower seat, Previous owner needed help looking over the dash.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 10-21-2020, 10:31 PM   #3
Getter-Done
Getter-Done's Avatar
A lot of these brackets have been swapped over the years.
Here is a old thread that is along this line of switching 60ish to 70ish.
link:https://67-72chevytrucks.com/vboard/...=seat+brackets
Here is a thread on the forum that shows the difference of the 67/72 brackets.
Link:
https://67-72chevytrucks.com/vboard/...ail+difference
The early bird gets the worm,
84 Chevy K-20
Old 10-22-2020, 02:39 AM   #4
pjmoreland
pjmoreland's Avatar
That would be nice if that's all it is. Then I could just remove the extra foam and reinstall the upholstery.
Old 10-22-2020, 02:44 AM   #5
pjmoreland
pjmoreland's Avatar
The seat bottom is about 8" thick and its metal frame takes up about the first 2-3/4" of that.
Old 10-22-2020, 12:18 PM   #6
jimijam00
Pics and measurements of different seat brackets here.
jimijam00 is offline   Reply With Quote
Old 10-22-2020, 01:05 PM   #7
HO455
HO455's Avatar
This thread and the links in it show pictures of most of the 67 to 72 seat frames that were used. Yours is a full foam seat and I believe there are pictures of all the different full foam seat frames.
Plus I have more pictures of 69/70 frames and the 71/72 frames full foam frames if you need something specific.
https://67-72chevytrucks.com/vboard/...d.php?t=804108
RIP Bob Parks.
Old 10-22-2020, 01:09 PM   #8
Astro-Balls
PJ, what is the year of your truck?
Old 10-22-2020, 01:33 PM   #9
pjmoreland
pjmoreland's Avatar
Based on the measurements shown on that site, I definitely have 69-70 seat brackets.
Old 10-22-2020, 01:35 PM   #10
pjmoreland
pjmoreland's Avatar
My seat brackets have been identified. I am still wanting to positively identify the seat itself though. Does an 8" bottom cushion/frame thickness seem pretty standard, or is it thicker than usual?
Old 10-22-2020, 01:36 PM   #11
pjmoreland
pjmoreland's Avatar
My truck is a 68, but the seat and brackets are not original. The previous owner replaced them with a seat of unknown origin.
Old 10-22-2020, 01:50 PM   #12
Astro-Balls
Got it, when you need foam, this might help.
http://www.americancushionind.net/pr...chevy-gmc-kit/
Old 10-22-2020, 01:54 PM   #13
pjmoreland
pjmoreland's Avatar
Thanks. It's interesting that it says 6" thick foam in that product description. I'm thinking my 8" thick seat might be 2" thicker than normal.
Old 10-22-2020, 02:03 PM   #14
SkidmoreGarage
Looks like it could be a non-folding 67 seat frame (if such a thing exists) with the lower padding from a later bench (this is what is commonly available new). That will give you the booster seat effect. Great looking seat from the pictures!
Take a look in my build thread at my 67 seat reupholster project. Some good pictures of the seat frame that could help ID what you have.
Not sure if you were asking for this, but you can carefully remove the lower cover and replace the thicker foam with the correct thickness and recover with new hog rings.
SkidmoreGarage is offline   Reply With Quote
Old 10-22-2020, 02:40 PM   #15
pjmoreland
pjmoreland's Avatar
The photos from your build thread are very helpful. I'm thinking I'm heading down the path of tearing the seat apart to see what's going on inside. I haven't done any upholstery work on 67-72 trucks, but I did replace the upholstery on a 350Z I had, so I'm familiar with hog rings.
Nice Ripmo, by the way. I've got a SC Bronson and I'm a total MTB addict. Bikes come first on my list of obsessions, followed by trucks.
Old 10-22-2020, 04:51 PM   #16
SkidmoreGarage
Happy they helped. Good call to take it apart (carefully). It isn't rocket science but it is surprisingly time-consuming. Be ready to improvise. You can see what I had to do.
My last MTB was a SC Bronson, sold it to buy the Ripmo. I see you are in Auburn, small world. I lived in Davis for school, and a little while after. I worked in Carmichael. I did a bit of mountain biking years ago with some friends up Clementine and down some trails (I was on a race hardtail, so they seemed intense at the time). I think I went through a tunnel? I also made a few trips to Salmon Falls. Do they still have the half iron triathlon in Auburn every year? I did that one year.
Old 10-22-2020, 04:59 PM   #17
pjmoreland
pjmoreland's Avatar
If you rode through a tunnel, then that was the Culvert trail, which takes you back down toward the canyon from the top of Clementine. Yeah, most of the trails in Auburn are pretty tame, but I like being able to ride straight from my house. I spent five years in Davis when I was in school. It sure is a small world. My grandma lived in Portland when I was a kid (Lake Oswego), so we spent a lot of time up there. It's a nice area.
Time to dig out the hog ring pliers...
