Old 02-10-2015, 01:41 PM   #1
rmv23887
Fuel line recommendations
72 LWB LS swap tank behind axle and I Need recommendations how people have done the fuel lines? Braided stainless or solid line with short braided stainless at ends?
rmv23887 is offline   Reply With Quote
Old 02-10-2015, 02:33 PM   #2
kamikazekyle05
kamikazekyle05's Avatar
Re: Fuel line recommendations
Ill be installing all braided stainless on mine in a couple of weeks
kamikazekyle05 is offline   Reply With Quote
Old 02-10-2015, 02:53 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
As much hard line as you can run, then braided hose for the final connections to moving parts.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-10-2015, 03:05 PM   #4
rmv23887
Hard line steel,stainless or aluminum? 3/8? LWB or swb? How much?
Old 02-10-2015, 04:27 PM   #5
tinydb84
tinydb84's Avatar
Depending on where you live you might want to get PTFE lined hose for your braded stuff. Some of the additives in gas will eat through normal braded line.
David
Instagram: myfabguy
Old 02-10-2015, 08:45 PM   #6
truckdude239
truckdude239's Avatar
I used the ptfe braided line for mine
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-10-2015, 10:08 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
I used the newer NICOPP tubing (nickel+Copper+Iron) on one of my projects. Really easy to bend and it will not rust. I bought mine from this guy:
http://www.ebay.com/itm/CNC625-3-8-C...3D141563486115
Best price I could find at the time. It bends really easy and flares easy with a regular double flaring tool. There are coated flare nuts available for it too. Some of the auto parts stores carry it but it is more $. I don't know how it would do with the AN6 tool.
LockDoc
Leon
Old 02-11-2015, 02:11 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Steel imo.
3/8 feed, 5/16 return if you need it. I can't tell you how much, that depends how you route it. Protip: buying a 20ft roll of 3/8 steel line is the dirt cheapest way to get it, and its very handy to keep around the extra, as you WILL mess up somewhere.
Technically any of the hardlines will work, however if you plan on using the hardline-braided line AN tube adapters, you need to be careful with the softer options like the aluminum, or the very hard like stainless.
Soft lines can get over-bitten by the fittings, and can chafe or puncture from repeated bending (which happens if you don't have properly designed braided/hose sections to absorb the movement).
Stainless lines are harder than the ferrule in the fittings, and sometimes it means the fittings don't get a proper bit and seal on the line. This can cause a little leaking from the base of the fitting.
Old 02-11-2015, 10:36 AM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
I agree with brew in regards to the hard-line.
I ran braided from the sump to the pump and to the frame-rail. Then hardline up to the engine where I split it off in braided again to the back of the fuel rails.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-11-2015, 12:39 PM   #10
Marty68
Wasted income ^^^ that is NICE ^^^
Marty68 is offline   Reply With Quote
Old 02-11-2015, 02:54 PM   #11
UP GRADE
one set closer
UP GRADE's Avatar
Hey wasted income where did you get dose clap that holding the fuel line to the frame?
UP GRADE is offline   Reply With Quote
Old 02-11-2015, 03:04 PM   #12
Wasted Income
Boosted Member
I got da clap from a long drunken night in Nogales, MX.
I got the clamps from summit.
http://www.summitracing.com/parts/sum-g1882/overview/
Turbo diesel
Old 02-11-2015, 03:38 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Whats the Y in the supply for? Nitrous enrichment?
Old 02-11-2015, 04:39 PM   #14
Wasted Income
Boosted Member
Reduced from single -10 to dual -8s to feed the fuel rails.
I also did the return line in hard aluminum, up to the flex fuel sensor, then went braided back to the tank.
Turbo diesel
Old 02-11-2015, 06:48 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Is there a flow advantage to doing it that way? I've looked at a few aftermarket rails setups for if I switch my intake off, but I usually see it fed from PS and then to a crossover, with the other rear port being a return.
Where does your return exit the rail?
Old 02-11-2015, 06:54 PM   #16
UP GRADE
one set closer
UP GRADE's Avatar
Wow didn't pay attention to that thanks for the web site and hope you got that taking of LOL hehehehe
Old 02-12-2015, 11:23 AM   #17
Wasted Income
Boosted Member
I run dual inlet and outlets to and from the rails because I feel that is the most balanced setup.
This is also how Aeromotive officially states that a dual fuel rail, return style fuel system should be plumbed.
This is how it used to run.
This is how it runs now. Hard line out of the rails to the regulator, then down to the frame rail.
Turbo diesel
Old 02-14-2015, 07:23 AM   #18
Mjminino
Hey wasted, I tried to pm you but you're at your max limit on messages
Mjminino is offline   Reply With Quote
Old 02-14-2015, 02:02 PM   #19
lynnfield
The Waco Kid
lynnfield's Avatar
You can check out what I did here: http://67-72chevytrucks.com/vboard/s...=585899&page=5
Posts 107-118, 145, & 154
lynnfield is offline   Reply With Quote
Old 02-16-2015, 10:20 AM   #20
Wasted Income
Boosted Member
Cleaned it out.
Turbo diesel
Old 02-17-2015, 08:50 PM   #21
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
hows that new Holley hi-ram (that what they cal it?) intake working out for you? I've been eying that one for some time now.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-18-2015, 02:26 AM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not speaking for him, but I know a few people with it who LOVE the thing...IF you got hood clearance for it. Its one of the highest flowing intakes without going to a single plane and all that jazz.
Old 02-18-2015, 11:20 AM   #23
Wasted Income
Boosted Member
Yea, it's working pretty good for me, and looks outstanding. I had planned on running the sandwiched A2W core from my bud Blake, but it wouldn't clear the doghouse on the firewall of these trucks. At least mine wouldn't.
Turbo diesel
Old 02-18-2015, 12:01 PM   #24
tinydb84
tinydb84's Avatar
Anybody use this stuff yet http://www.speedwaymotors.com/Black-...6-AN,8976.html
I'm sure some of you have seen the parker push lok that sloppy mechanics uses but this actually says fuel line. I wonder if it is any good. Speedway says you can run alcohol and diesel through it too.
David
Instagram: myfabguy
Old 02-18-2015, 01:27 PM   #25
solidaxel
solidaxel's Avatar
Me three !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
