Old 01-25-2021, 11:11 PM   #1
truckster
truckster's Avatar
Catalytic Converters?
Have any of you added catalytic converters to your Blazer to reduce exhaust odor when you're running without the top? I'm thinking about it and wondering how well it worked for you. I have 2.5" dual exhaust exiting behind the rear wheels and my carb and timing are properly adjusted.
Thanks.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is online now   Reply With Quote
Old 01-26-2021, 08:50 PM   #2
hemi43
hemi43's Avatar
Re: Catalytic Converters?
What engine are you using? You can't just put catalytic converters on and expect them to last especially with a carb. They need oxygen to work either by the use of an air pump or one way valves that suck air into the exhaust.
The best thing you could do is get rid of the antiquated carbureted engine and install something late model. At the very least, get rid of the carb and get fuel injection.
hemi43 is offline   Reply With Quote
