Old 08-02-2020, 06:24 PM   #1
pound41
Body mount bushing preference
Restoring 75 Silverado 4x4. Welding in floor pans looking for opinions on new body cushions . Rubber or Poly. Who makes good quality
pound41 is offline   Reply With Quote
Old 08-02-2020, 07:38 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Body mount bushing preference
as pricey as they are LMC has similar to factory.. I have used an aftermarket kit on one of my builds also rubber and didnt like them as well not looking factory at all..ive never used poly
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 08-02-2020, 08:18 PM   #3
The one time I used poly on a truck that did a fair amount of dirt road and field driving, the poly caused the sheet metal around the mounts to crack. The sheet metal was not thin, but the poly just doesn't flex enough. Great for suspensions in my opinion, but not for body mounts. I prefer the factory style rubber mounts.
Old 08-03-2020, 02:28 AM   #4
wixthedog
wixthedog's Avatar
Another vote for rubber. Poly is too rigid for me and too many squeaks to live with.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
Old 08-03-2020, 08:16 AM   #5
Katrina/10
Katrina/10's Avatar
I bought LMC rubber mounts for my truck, and they started cracking in short order. I wish I knew where good ones could be obtained.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 08-05-2020, 03:30 PM   #6
Mattchu60
I have the LMC rubber ones. I have not had issues with cracking after 3 years (knock on wood). However I remember they were a PITA to install - felt like that rubber doughnut needed to be about 1/16" larger on the inside, it took a lot of effort to get the top mount to fit into the bottom.
Mattchu60 is offline   Reply With Quote
Old 08-05-2020, 05:52 PM   #7
Axle
Axle's Avatar
No problems with energy suspension poly bushings. Would (will) do it again for my '81. Also run ES bushing on my nova, had them in since ES introduced them way back when. But I don't do field driving or very rough roads.
Axle is offline   Reply With Quote
Old 08-06-2020, 03:01 PM   #8
MJN
MJN's Avatar
I used Energy Suspension poly mounts too, they even survived a roll over.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-06-2020, 03:40 PM   #9
44th Miss Inf
One of my old C/10s is still running around here with a set ES polyurethane bushings that I put on it close to 30 years ago.
I had to change the factory rubber bushings on my 2000 k2500 5 years ago, and the body had been sagging for a few years when I did it then, so those rubber ones only last 12-13 years.
I made aluminum ones to go on my 67 Camaro
44th Miss Inf is offline   Reply With Quote
Old 08-06-2020, 09:58 PM   #10
fordguy40
LMC rubber on my C30, no complaints so far. Identical to the stockers, can't speak to their longevity since I put them on fairly recently. Go a long way toward making the truck feel tighter on the road and the cab's body lines now align with those on the bed.
A few Fords and a couple of Chevys
fordguy40 is offline   Reply With Quote
Old 08-07-2020, 12:27 AM   #11
87GMC1500
I’ve been running the poly graphite on a couple of c10s with success and no squeaks
https://p-s-t.com/i-23159818-polygra...mount-kit.html
87GMC1500 is offline   Reply With Quote
Old 08-07-2020, 01:55 PM   #12
Desert1957
Desert1957's Avatar
Why are the LMC kits so expensive?
Desert
Desert1957 is offline   Reply With Quote
Old 08-07-2020, 02:20 PM   #13
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
I'm using rubber. After my experience with several vehicles over the years, I would never use poly on anything other then sway bars, and that's mostly due to not being able to find real rubber sway bushings anymore.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 08-08-2020, 05:15 AM   #14
wixthedog
wixthedog's Avatar
Those are neat, I may give those a try. Wish I could find more information and reviews on them though.
Mike
Old 08-08-2020, 02:43 PM   #15
Axle
Axle's Avatar
PST has been around a long time, and if I remember right considering its been so long ago they may have been the first ones to introduce the graphite impregnated poly suspension bushings to combat squeeking (not something you'd encounter with a body bushing)
Old 08-12-2020, 07:18 AM   #16
rustyfive-seven
i used rubber kit from lmc and am very happy with it so far. body lines came back,doors close nicer and it rides better. I have no experience with poly bushings so I have nothing personal to compare.
rustyfive-seven is offline   Reply With Quote
Old 08-31-2020, 12:39 AM   #17
BK'66Step
BK'66Step's Avatar
Pardon me for hijacking the thread, I just bought ES poly bushings and am in the process of putting them on. After taking the front cab bushings off, I discovered the sleeve inside the bushing is rusted through and unusable. I found one kit that includes the sleeve, bolt, washer and new rubber for $32 but i was wondering if there was anywhere to purchase just the sleeve?
'78 K10 btw... If i can find them, I'll give you a comparison between the rubber i took off and the poly I'm putting on lol
BK'66Step is offline   Reply With Quote
Old 01-29-2021, 02:08 PM   #18
69Tom
69Tom's Avatar
Anyone other than LMC carry the stock style rubber kits? They're backordered and who knows when they'll get more in.
69Tom is offline   Reply With Quote
