![]() Join Date: Aug 2010
Wheel Backspacing With 73-87 Drop Spindles and QA1 Coilovers?
Running 15x8 (5x5 bolt pattern) rallies and wheels hit the QA1 lower control arm, barely scrapes the inside of the wheel right under the lip, with 1/4 spacer it clears. I believe a stock (non-dropped) spindle would clear.
Looking for wheels that will clear without a spacer. Anybody have QA1 upper and lower Control Arms and coil overs? What wheels are you using? 15x8 with 3.75" BS would work, but moves the wheels out. 17x8 or 18x8 with 4" BS should work. But looking at 17 or 18" wheels, many 17x8 or 18x8 have 4.5" BS, limiting my choices... I'm uncertain if this much BS would work. Once I nail down the wheels will look at tires. I'm running 235-75/R15 now. Have to raise up the coilovers because the tire will hit the fender bolt on big bumps. This picture shows one setting, it's too low, currently raised up a bit. ![]() Thanks for any insights! Roy
1965 Suburban Waiting on Time and Money |
