Old 02-09-2021, 04:17 PM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Horn Help
I am using a new AAW harness and dual Hella horns with a Billet Specialties wheel on a stock tilt column.
I've tested the horns right from the battery. They work. I put the green plastic piece with the copper on the column first, the spring, and then the wheel. Connected the yellow wire to the horn cap and the ground. No horn. Do I need more pieces other than the green plastic piece between the column and the wheel?
I did notice the relay was very warm so I pulled it out until I can figure out what I am doing wrong.
I have all the factory original pieces, but from reading the Billet Specialties instructions I only need to use the green plastic piece that has the copper ring on it. Any help is appreciated.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 02-09-2021, 04:27 PM   #2
sick472
sick472's Avatar
Re: Horn Help
I had a similar problem where my multiple horns were pulling too many amps and I had to upsize the relay. FYI - My system was all stock except the 4 Cadi horns...then the new style 30 (?) amp relay addition. Just something to consider as well, I'm not sure what the Hella Horns are pulling.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-09-2021, 07:55 PM   #3
BigBird05
Re: Horn Help
By pass the relay to test it. If by adding power to the wire that goes to the horns ( hot wire to horn wire) makes them work then reconnect the wiring harness and apply a ground, if the horns don't work you need a new relay. If they do work then the problem is in the wiring between the relay and your horn button.
BigBird05 is offline   Reply With Quote
