![]() Join Date: Aug 2010
72' Blazer interior assembly tips?
I'm getting ready to bring my Blazer home and start reassembling it. Does the rear carpet and wheel well carpet go on first and then the interior side panels or side panels first and carpet last? Thank you.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
![]() Join Date: Jan 2004
Re: 72' Blazer interior assembly tips?
How cool ! I do not know, but I am subscribed since I will be doing one in a couple weeks.
![]() Join Date: Jan 2001
I'm pretty sure it has to be carpet first.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Carpe manana
![]() ![]() Join Date: Dec 2010
Why not keep it original style and skip the wheel tub carpet? Only mentioning because I've had problems fitting the Truckworld rear panels over carpeted wheel tubs and skipped this carpet on my current blazer. If I remember correctly, the carpet for CST goes up to but not deep to the panels (blocked by the panel brackets along the bed floor). Make sure the carpet is for a CST application.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#5 | |
Posted via Mobile Device |
#6 | |
Carpe manana
I like the contrast of color that comes from the exposed wheel tubs and step face. The jack and posi instruction decals affix to the rear face of the LH wheel tub.
![]() Join Date: Jan 2018
Yep, Pete is correct again!
I just recently went through this with my '72 Jimmy. If you have a CST option, be sure to order the carpet for CST trucks. The side panels go on first and then the carpet lays in, and up to the sides of the panels. If you order the carpet, absent specifying the CST option, you will then get carpet that is designed to go all the way to the sides of the bed area. Again (as Pete referred to), I just left the wheel well carpet completely out. The wheel-well carpet will not fit, under and behind the side panels. Pat |
#8 | |
#9 | |
I guess you just never know when these trucks are pushing 50 years old! LOL! Pat |
