Old 11-06-2022, 07:25 PM   #1
79vette
What do you do for tie down points on your flatbed?
I put an underbody tool box on my 88 C30 today, and I had to mount it flush under the bed for ground clearance. I used to use wire hook straps sort of jammed under the edge of the bed rail, but that was kind of sketchy and I had one pop off once. With the toolbox now I couldn't use that strap type even if I wanted to. See picture below.
I have a ton of snap hook straps and stake pocket D rings I use with my trailer, and I really like those since they don't come off even if the strap becomes loose.
I'm thinking about adding stake pockets and rub rails like I have on the trailer, but that is pretty heavy and kind of a pain. I'd like to keep the top surface of the bed flat for any oversized cargo, so welding d rings to the top surface of the bed frame is out. What would you do to safely attach tie down straps to the truck in this situation?
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread
1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread
1979 Corvette - 350 T5
1977 Jimmy - 350, TH400, NP203
1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck
Scratch built 16' flatbed trailer - thread
79vette is offline   Reply With Quote
