What color "white" for wheels?
I did a quick search but I came up dry...
What is the correct, or closest to, shade of white for my truck's steel wheels? I will be putting a set together soon, wanted to paint them before I mounted the rubber. Oh yeah...looking to do this ala rattle can. Someday I will do it right with rest of truck, I need fast and accurate now. ![]() Thank you.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
Re: What color "white" for wheels?
semi gloss white?
78K & 79C Jimmys
I used a tremclad rust paint gloss white
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I used duplicolor white steel wheel paint from Kragen or Auto Zone. I don't know if this is the correct factory color, but it looks fine.
Next!
I used Rustoleum gloss white, pretty close to original look.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
Look for this one. It is white with just a bit of blue in it. The guys on Chevytalk claim it is a perfect match.
Duplicolor Truck, Van & Suv # T174 White/Blue |
Thank you all for the responses. I will look into those suggested.
Does anyone know the correct stock color name? And are the bumers the same color/shade?
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
#9 | |
Yes, the same shade of white was used on bumpers as well as some mirrors. And it was also available as an exterior color (common on many 2-tones). I used some Nason Ful-Thane urethane mixed in GM code #12 to spray these wheels for Dad's 77 ![]() |
semi gloss rustolem
Rust is better than rice. ![]() |
#12 | |
bringing this one up from the dead and adding my $.02 since this is what I found while asking the same question
![]() Quote:
and I was informed that powder and liquid colors aren't necessarily the same.. so the factory white chevy wheel I brought for sample looked to have a skosh of blue in it as mentioned above.. the four of us agreed on Axalta Glacier White PFW500S9 comparing colors in clear daylight.. https://axaltacolorcard.com/node/2224 ![]() turned out pretty good, for my eyes anyway.. if I can remember I'll post some pictures with rubber mounted on them ![]() ![]()
I started out with nothing - and I still have most of it |
I'll be using Frost White since my truck has that color under the trim line and on the roof. It appears that Frost White is available from automotivetouchup.com. However, this is a quote from their website when I looked up the paint: "AutomotiveTouchup paint products are custom mixed to perfectly match the color of your 1982 GMC All Models using a basecoat/clearcoat system just like factory specs." That little blurb there, doesn't inspire much confidence, since those trucks had single stage paint. I checked to see what DupliColor had to offer and their perfect match premium automotive paint line now consists of six colors that they call "universal"... it appears that they are out of the 'dupli'cating business or that their website navigating logic is not up to the task.
Another quick side note, if you are trying to match an existing color. I have two trucks that are painted colonial yellow. One is painted over a black primer and the other is painted over a white primer. It changes the color noticeably. So it is worth approximating the primer color before top-coating if trying to match. Not terribly important on wheels though. |
^ good point on the matching factory colors, reminds me of something..
after I got home from dropping off wheels at powder coater I wanted to look up the color we chose.. I wasn't getting the warm fuzzy I was expecting regarding factory color names so I called Axalta to see what they had to say.. the territory rep called me back fairly quickly and we had a nice chat about powder coating ![]() he explained that they are required to obtain permission from the manufacturers to use licensed names of color codes and the fees are steep.. and since there are so many colors and competitors is just isn't worth it to obtain all the credentials to name and advertise their products with reference manufacturer's color.codes.. of course larger companies may do this for certain brands or colors they can sell in volume to be profitable.. and I would imagine the company that made the actual paint for the OE would have some rights to use the factory codes.. but it's just not an economical option for every other paint company..
#15 |
You wouldn't think white paint on wheels would be such a big deal but the correct shade is very important. I made the mistake of painting some in the wrong shade and it bugged me for a couple years until I changed it. The primer color makes a difference too like LT7A said.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#16 |
83GMCK2500, I see that you hail from both Washington and Oregon. Wesco Auto Paints ought to be able to mix you a couple of cans of Frost White to match the factory color. Not super cheap, but quick.
#17 |
Thank you for the recommendation. They have a Portland location, not far from me and not in the middle of the trash.
#18 |
Aside from GM 12, there is also a code 11 white.
Tags |
4x4, paint, steel wheels |
