Old 05-19-2021, 06:38 PM   #1
Accelo
Accelo's Avatar
The simple things should fit, (shouldn't they)
Working on what I figured was a 5 min project. Bolting a stock inner fender support to the inner fender. You know the one that spans the gap in the inner fender where the steering column goes through.
I could get the back too bolts in and the one furthest forward almost would go. The second one back was not even close. Not only was the bolt hole not spaced correctly it was too far in for the brace to fit flat, as in the holes were not punched in a straight line. So, I elongated all the bolt holes so I had a chance of getting the bolt in and the washer covering the hole. After that I could get the front bolt in, some progress. Then I started slotting the second hole from the front. I wanted to slot as little as possible as the brace would be getting thin. Well, it worked. Bolt hole was covered by the washer but just barely. Pictured in the last photo.
Test fit every piece! I had already powder coated the brace, thinking what could go wrong. An hour later I was done!
God Speeds in Trucks!
Rick
Accelo is offline   Reply With Quote
Old 05-19-2021, 07:00 PM   #2
Barnfind46
Barnfind46's Avatar
Re: The simple things should fit, (shouldn't they)
These are the things that make restoring old trucks such a pain. In the 90's I would just look for used oem parts but now even the parts truck I bought has poor quality replacement parts here and there. Guess I should just be happy I can still do this and parts are available.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 05-19-2021, 07:14 PM   #3
gmc684x4
The one thing I am happy about is far more available parts today for my 68 gmc then was available in 1990
All except nos parts they keep getting less each year
gmc684x4 is offline   Reply With Quote
Old 05-19-2021, 07:17 PM   #4
Boog
laying low
Boog's Avatar
There is an awful lot to be said for NEW metal. Even if it needs a bit of tweaking. No rust no rust no rust!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-19-2021, 10:10 PM   #5
Davidf
Rick
My experience was the same
Davidf is offline   Reply With Quote
Old 05-19-2021, 11:21 PM   #6
Getter-Done
Getter-Done's Avatar
Well Said.
The early bird gets the worm,
84 Chevy K-20
Old 05-20-2021, 10:48 PM   #7
RustyPile
RustyPile's Avatar
When I put the front end back on my truck I started those 4 bolts before I started any of the others.. A couple of the bolts on the fender didn't exactly line up.. A drift inserted in an adjacent bolt hole was used to get those started.. After all the bolts were started, including the one in the body brace and the 3 in the core support, I tightened all of them..
RustyPile is online now   Reply With Quote
Old 05-21-2021, 12:45 AM   #8
Accelo
Accelo's Avatar
I agree that new is good and more parts are available now than were 10 years ago. For that I am grateful. However, it is not any more difficult to make a good part than a bad one. I thought it was a good suggestion about putting the brace on first. However, I couldn't get that bolt in if it was the only one I started.
Well it would start but the brace wouldn't set flat as it was so far inboard the angle, where it drops below the inner fender, would set on top instead of over the edge like factory.
Happy days, it's in and no one knows but me and 500 board members. LOL.
Thanks and take care.
Rick
Old 05-21-2021, 09:07 AM   #9
palallin
What value is there in No Rust if one has to damage (and thereby initiate rust formation) in order to install the part?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 05-21-2021, 11:02 PM   #10
Getter-Done
Proper prep work of modifications ,
May require removal and installation ,
Several times ,
This:
Will be a Positive thing
84 Chevy K-20
Old 05-22-2021, 01:20 PM   #11
Bigdav160
Bigdav160's Avatar
I think they make a tool for that
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
