Old 06-14-2021, 01:34 AM   #1
lux
T400 help please
I have a 383 with a T400 transmission and BTE 310800 11” converter Stall Speed 2600-2800 rpm.
On my last drive the trans would not shift until it reached 4000rpm.
What could be going wrong?
What should I look for?
Thank You
lux is offline   Reply With Quote
Old 06-14-2021, 06:08 AM   #2
cadillac_al
Re: T400 help please
Check the vacuum line for full vacuum.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-14-2021, 11:25 AM   #3
kwmech
Vacuum line most likely---OR the governor (under the 4 bolts on the side) has stripped a gear from the bushing walking in the case
Old 06-15-2021, 12:42 AM   #4
lux
Thanks guys, I know the vacuum line is hooked up but, what's the best way to test it?
Old 06-15-2021, 01:22 AM   #5
kwmech
Hook a vacuum gauge to the line at the trans
Old 06-16-2021, 10:39 AM   #6
SunSoaked
SunSoaked's Avatar
I had same issue bit I had my vacuum advance cannister off the HEI T-d into it. The diaphragm in the cannister went bad and raised my shift points like you.
SunSoaked is offline   Reply With Quote
Old 06-16-2021, 11:25 AM   #7
lux
i have my vacuum line straight to the intake on a Edelbrock pro flow 4. I made sure and use hard line for most of the route with rubber fittings on the ends.
I'll get a chance to look at it this weekend. Hopefully its just a line that came unattached.
Old 06-20-2021, 08:51 PM   #8
lux
Well, I tested vacuum at the transmission it was 20-22 at 3000rpm. Does that sound about right?
Then I checked the kick down switch and it was stuck on. I took the Lokar switch apart and sprayed it with silicone lube. That seems to have done the trick. All is well now, thanks for the help.
