![]() Join Date: Sep 2002
To de-smog or not to de-smog
Thinking of picking up an 86 GMC Sierra classic that is all stock. Has a 305 with smog pump still hooked up. Would like to get the engine breathing better with an open air cleaner & eventually headers with dual exhaust.
I know its been discussed b4 but what advantages or dis-advantages r there in removing the smog pump & related hardware? Should I just remove the belt or will that cause more problems than its worth? Dont have to worry about inspection as it will be registered as a classic. Also I may be towing a car trailer from time to time so any performance improvement would help. Any info or suggestions r appreciated. Thanks Scott
1963 C10 swb fleetside 1966 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
Re: To de-smog or not to de-smog
If you don't need any of it for inspection I'd remove it.
Square
I did it to mine, I saw absolutely zero difference performance wise, but it looked so much better.
Squarebody Syndicate |
The open air cleaner, while looking cool really just feeds the motor with heated air. Not so good. We use the factory air cleaner base with the "tall" truck lid. I use a Holley so I had to use a 1" spacer under air cleaner base. Plug all the holes not needed and use the factory pipe that goes to the core support. Cut off the baffle for increased air flow. Coat of paint. Now you have a functional cold air intake in the "cheap"
Take all that smog crap and toss it directly in the circular file.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
Thanks guys, appreciate the info.
Bump.
I have an 81 Silverado, 305. I wonder if I should remove the smog junk, or if it isn't worth the trouble. If yes, are there any step-by-step tutorial Thread? Thanks. |
Check your state's rules first. It will suck if you yank stuff off only to find you need it to pass any inspections you might have. In most states, illegal to pull cats even if you don't have inspections.
Things to keep: THERMAC - helps engine warm up on those cold mornings. Zero impact once engine hot. PVC - removes blow by and condensation from crankcase. Since modern carbs are calibrated for PVC, removing can screw things up. Charcoal canister - provides vent for gas tank and captures evaporated fumes from tank. Near zero impact on performance. If you have a vacuum advance, try moving it from ported to manifold vacuum. Most folks get a decent low to mid range performance boost. |
![]() Join Date: Apr 2005
I want to pull the smog stuff off of my 87 Jimmy (350 TBI/ 700R4 Trans/ true duals). What can go? What has to stay? Thanks!
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I would check state laws first then go from there.
Just here to tinker
![]() Join Date: Jun 2008
I honestly don’t think you’ll notice a performance gain on the TBI motor. It may just end up making the engine throw codes constantly and keep the light in the dash on. I had a TBI V6 and instead of removing everything, I just got a shorter serpentine belt to leave the smog pump out and left all the equipment there. That way if I needed to, I could just put the bigger belt back on.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#13 | |
Active Member
![]() Join Date: Jan 2017
The AIR Pump is ON/OFF by the computer, the computer receives no information on it so removing the AIR system does not affect anything. EGR removal would require a program change.
