Original Throttle linkage to Edelbrock Carb?
Has anyone adapted the original throttle linkage to an Edelbrock Carb?
Any pics? |
Re: Original Throttle linkage to Edelbrock Carb?
Here is one link where that has been answered.
http://67-72chevytrucks.com/vboard/s...rottle+linkage If you do a smart search for throttle linkage you will find several threads on the subject. |
I bought a round stock 1/4" with Mr. Gasket linkage bushings. Works great!
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
I Used the original linkage.
http://67-72chevytrucks.com/vboard/a...1&d=1601860722 http://67-72chevytrucks.com/vboard/a...1&d=1601860722 :Ito:Jim |
[QUOTE=doobiebro;8817097]I bought a round stock 1/4" with Mr. Gasket linkage bushings. Works great!.........I must have saved your photo, posted on another thread, nice clean set up.
If I wanted to do my throttle rod like the pic in post #4, what parts do I need to buy? As of now I have something a bit substandard rigged up to the smaller hole on the carb arm with a cotter key. Maybe it was my stock 2 bbl stuff. I thought about this one, just not sure if the threads on the stock rod are 1/4-28. https://www.summitracing.com/parts/afc-10171
A few things I learned in trying to hook my stock V8 pedal bell crank to the large hole on the carb like this https://www.fordmuscle.com/archives/...rottleLinkage/
The threads on the stock linkage rod are 1/4 -32 so I made a 1/4-28 rod as seen in the tutorial and bought the heim joints and stuff. Thing is, the geometry with a straight rod didnt work because of the arc in the carbs travel and no matter how I bent or altered the rod (J bend, Z bend etc) i never could get full trave on the carb. I could set it up connected at full throttle and the carb wouldn't fully close when I let go. Conversely, if I set it up for the carb at idle, it would only pull part way open. I believe the problem lies in the fact that the large hole begins pulling back and downward as it crosses the apex mid throttle when you floor it. So now its back to this which wiggles a bit but gets full travel Last edited by AcampoDave; 07-24-2021 at 03:14 PM. Reason: Added a pic |
