Old 08-13-2021, 02:28 PM   #1
geunther
geunther's Avatar
Engine Condition Input
My engine/transmission were leaking so I pulled both to seal them up. Both are original to the truck and in good shape. The engine has good compression, runs great. Really the only issue was oil leaking.
I pulled the rear main so I could replace the seal. The bearing does show some wear as you would expect. The bearing markings (GMM) indicate likely a factory bearing which matches the date code. The bearing size shows 001.
Now, I was hoping to replace rear main seal, new pan gasket and move on. With the bearing wear, should I replace the mains or does it look fine for the next 10k miles or so to you guys with a lot of engine experience.
Also, assuming its a no brainer to put in new oil pump?
geunther is offline   Reply With Quote
