Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-13-2021, 08:05 PM   #1
Johns 66
Johns 66's Avatar
Electrical Question for Dim Headlights
Hello Peeps,
Got a question and not sure where to turn.
My headlights are dim, when I rev the motor they get brighter, at idle they go back dim.
I thought it may be a grounding issue so I changed the battery ground and added a better ground to the headlights.
so Im clueless at this point....
Im sure its an easy fix except Im not that knowledgeable about it.
I appreciate it,
John
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 09-13-2021, 09:10 PM   #2
lutronjim
Re: Electrical Question for Dim Headlights
Check battery voltage at idle - sounds like alternator is not putting out at idle.
lutronjim is offline   Reply With Quote
Old 09-13-2021, 09:34 PM   #3
Johns 66
Johns 66's Avatar
Will.defintely try that...Thanks so much
2019 GMC AT4
Old 09-13-2021, 10:03 PM   #4
bhap
bhap's Avatar
You may want to install a couple of relays up near the voltage regulator / horn relay. Taking power directly from the alternator/generator to the relay will eliminate the long run to the headlight switch and the high beam switch. Do a search for "headlight relay" on this forum - you should find several wiring diagrams for the relays. It made a big difference with my headlights.
bhap is offline   Reply With Quote
Old 09-14-2021, 06:57 AM   #5
cwcarpenter98
cwcarpenter98's Avatar
I remember having that same problem on my truck. After I put the headlight relay harness on, I think that issue went away, but I'm not remembering for certain if that's the case. Since I'm not remembering correctly, maybe that means the relay harness fixed that for me.
If your truck doesn't have a relay harness, definitely add one. They aren't too expensive, easy to install, and well worth the money. The stock headlights in my truck got way brighter with the relays. One of them burned out a couple weeks later, but then I was able to swap to some halogen bulbs which were even better. At the moment, my c10 throws better light than my 95 Dakota. Apparently, Dodge didn't start using headlight relays until some time after 1995, so that'll have to get fixed at some point too
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-14-2021, 09:01 AM   #6
Bigdav160
Bigdav160's Avatar
Too many places to lose voltage on the power side of the circuit. Relays should solve that problem
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-14-2021, 10:38 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
For your year truck here is a great thread with great ideas on how to do it along with many links on the subject. http://67-72chevytrucks.com/vboard/s...d.php?t=397695
Old 09-14-2021, 10:04 PM   #8
Johns 66
Johns 66's Avatar
Thanks for the info guys it is greatly appreciated....I will be re-wiring the entire truck in the coming weeks and the relay seems to be the key to headlight function...I think Andy used these on his truck as well so I will definitely be adding these to mine.....brighter headlights are definitely a plus
2019 GMC AT4
Old 09-15-2021, 12:02 AM   #9
Dead Parrot
My 75 had that problem. Switching from the 10SI Alternator to a 12SI fixed it. The 12SI puts out about 7 amps more at idle then the 10SI.
If you are still running an externally regulated alternator, swapping to an internal regulated when you do the re-wire might be a good idea. BTW, the internally regulated 10SI and 12SI both use the same connectors.
Dead Parrot is offline   Reply With Quote
Old 09-15-2021, 11:05 AM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
check my FAQS in the threads at the top of the electrical forum page.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-15-2021, 11:16 AM   #11
Wrenchbender Ret
You have some real good replies here. Also check the battery. A bat. getting weak can cause that also.
George
Wrenchbender Ret is offline   Reply With Quote
