Do I need to add a fuse??
I'm wiring a fuel pump/oil pressure safety switch on my 64c10 using this layout:
https://www.tanksinc.com/pdf/fuel_pu...structions.pdf I need to run a wire to the "I" terminal part of the switch. Do I need a fuse on that wire to the "I" terminal of the safety switch? Is it a safer bet adding one even though the instructions don't say to use one? If so, what amp fuse do I need? |
![]() Join Date: Nov 2012
Re: Do I need to add a fuse??
The relay draws very little current, less than 1 Amp. A fuse in the pink wire is not necessary but if it makes you feel better it will not hurt anything.
