Old 10-06-2021, 01:42 PM   #1
ck1insac
Gear Pattern - Pinion Depth
Hey guys, my first rear end build on my Chevy 12 bolt. My main question is regarding the straight line at the bottom of my gear pattern. I’ve read several threads where it’s an indication of the pinion being too deep. However, adjusting the pinion, I get similar patterns. I’ve gone down to .020 pinion shim. These pics are using a .030 pinion shim and a backlash around .008. This is a new Eaton TruTrac carrier, and new 3.73 Motive Gears. All bearings and races new as well. I’m in no rush and just want to do it right. Any recommendations or insight would be much appreciated.
ck1insac is offline   Reply With Quote
Old 10-06-2021, 07:42 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Gear Pattern - Pinion Depth
Don't the new gears give a pinion depth number that you are supposed to set it to?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-06-2021, 08:49 PM   #3
kwmech
Without seeing the pattern with a 20 shim I'd be inclined to leave it there. Do you have a .025 to toss in there?
Old 10-07-2021, 02:33 AM   #4
Accelo
Accelo's Avatar
I ground down the I.D. of a bearing set so I could change shims without pressing them on and off. There is little difference between bearings so once it's set I can press the bearings on once. Did you carry the marking paint all the way to the edge of the tooth? It looks like you stopped painting at the outer edge. If it's the pattern hitting you have issues. If it was just lack of paint it looks pretty good to me.
A lot of Videos out there but this is one of my favorites;
https://www.youtube.com/watch?v=nVb5WRUfM7Y
Accelo is offline   Reply With Quote
Old 10-07-2021, 09:32 AM   #5
BigBird05
It looks a little deep, but you could live with it. Much better that to far out.
BigBird05 is offline   Reply With Quote
