boyds tank in tank fuel pump questions
What have some of you used in boyds tank for the fuel pump ? I see boyds offers a pump but it seems expensive for the bracket he makes.
I know I can have it made myself for a lot cheaper then that. I just need to find the right Submersible Pump bulk head terminals and the weld in fitting for the fuel line. I do not know were to find those parts yet so asking here to see what others have done. My boyds tank has the clean out plate/ring that is used for the fuel pump. |
![]() Join Date: Jan 2011
Re: boyds tank in tank fuel pump questions
I think the plate they are using now is a billet machined one. Summit, Jegs and Boyd welding all have the weld in bungs. I am running there tank with the intank pump with a return regulator with a carb. Dont forget to order the insulated fitting for the power to the pump.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Did you buy there in tank kit or make your own ? I think at $230 for them to weld in the bung and connect the wires and weld the stand is a bit steep, the 340 areomotive pump there using is only $118
I got the entire tank. The still have to make the parts, not just weld them up for $230. And like I said I think the new ones are cnc machined and not water jet cut. Look at the picture of the pump setup in the tank section. It's not the same as the old one pictured in the pump ad.
Jimmy
I looked at it just now, it is not much different then what I have and not worth the extra $230 when it should be about $30 in parts.
I can not believe I am the first one to want to do this, Hopefully someone will respond to the original question. |
Interested as well same problem. I’m just too cheap. Sure it’s of great quality like their tanks
71 C10 Finally took a leap and did the 5.3 4l80e swap. Running the Holley Terminator Xmax. Still working bugs out. ![]() |
I have a boyd tank mounted in the rear of my 72 stepside. I am just going to drop in a 98-02 F-Body pump assembly. All you have to do is get a ring cut for the top to clamp it down. Like 40 bucks on rock auto for the pump assembly. You can even use the truck ones and shorten them. I am just going to swap the pump for a walbro 450 which is a little over 100 bucks. Only because I am going E-85 and may slap a turbo on in the future.
i have a walbro GSS342 in mine
it's a bit higher pressure...runs dead headed (no return) 58 psi
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
Collector of Projects
Thanks for the suggestions but the boyds tank already has the solid ring so just looking for aluminum weld in bung and electrical bulk head connectors.
Can you drill holes and use AN screw on bulkhead fittings for feed/return and hang the pump off the fitting?
Do you already have a fuel pump? If you don't then the OEM fuel pump assembly I suggested takes care of your issues. It already passes through the electrical connections. You won't need the vapor works ring either. Just cut a hole in the cover plate provided by Boyd's to pinch down the pump assembly and your done.
I sent you a message , we live close so checking it out would be great.
I used a tanks universal in tank set up. Worked out great
OLDIRONRACING |
#15 |
I finally got my EFI pump set up done and have $180 in it with the welding.
It looks like what boyds offers. I had a local welder weld a piece of aluminum angle iron on my clean out and had him weld the gas line fitting. I used these parts from summit wire thru bulkhead fitting # ABT-CFD-504 6AN male to 5/16 barb # SUM-220188B and the fuel pump # AEI-11542 ( the gas line that comes with the kit is only 4" and you will need a 5 1/4" gas line for inside the tank.) Last edited by my kids toy; 10-21-2018 at 04:25 AM. |
#16 | |
Posted via Mobile Device |
