Old 11-07-2021, 12:47 PM   #1
weim55
Need measurement for clutch rod hole in firewall ‘67 C10
I just dropped a 67 GMC cab onto my 67C 10 chassis and found the first difference: The 67 GMC had a V6 NP435 4 speed and it appears the hole in the firewall for the clutch rod is in a different location than the Chevy. The second picture posted is of a 71 Chevy cab which I think is a little bit different than the 67 Chevy. Would one of you guys be able to get a measurement of the hole placement on a 67 Chevy cab?
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 11-07-2021, 02:42 PM   #2
georgieb51
georgieb51's Avatar
Re: Need measurement for clutch rod hole in firewall ‘67 C10
I think you blue cab shows the correct clutch rod hole. In my photo I am pointing to the hole.
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
Old 11-07-2021, 02:52 PM   #3
weim55
The 71 cab “ bumps out“ The area of the clutch rod hole larger to the right side of the vehicle. I looked at a complete 71 I have and the clutch rod has a dog leg to match that slightly different hole. My 67 uses a straight rod coming through the firewall. The red cab you took a picture of looks like the same firewall forming as my 67. Do you know what year that cab is?
Old 11-07-2021, 03:11 PM   #4
Grumpy old man
Grumpy old man's Avatar
This is a 67 cab .
Old 11-07-2021, 03:13 PM   #5
georgieb51
georgieb51's Avatar
Refer to Grumpy's photo since his is truly a 67 and there are some differences in location due to the shape of the clutch rod.
Old 11-07-2021, 03:14 PM   #6
pjmoreland
pjmoreland's Avatar
Here's a photo I took a couple of months ago of a 67 Chevy that had an SBC and an SM420.
pjmoreland is online now   Reply With Quote
Old 11-07-2021, 03:25 PM   #7
weim55
OK, out in the garage now. Georgie and grumpy‘s firewalls look identical to mine. Could I get one of you to take a measurement of the diameter of the hole and an East West measurement to the lip of the firewall and north-south to the centerline of the master cylinder stud?
Old 11-07-2021, 04:21 PM   #8
Grumpy old man
The clutch rod hole is egg shaped as is the boot so a general measurement will just get you close , If you need a pattern made I can make one and mail it to you ?
Old 11-07-2021, 11:28 PM   #9
weim55
I took the last picture that you posted and scaled it, made a template, used a holesaw to get it close and then finished it out with a die grinder. Sized it to an original boot and it works perfectly! Thank you very much for that it saved the day and the truck was able to drive out of the garage under its own power!
