![]() Join Date: Nov 2013
I'm going to order a new dash panel. I want the threes hole speedometer, tach & Fuel. I don't want the four holes on the bottom. I'm going to put my own gauges in. I will drill & install Autometer. Anyone got pictures that have done this. I know I can't be the only one with this idea. Thanks
![]() ![]() Join Date: Jan 2005
Re: Dash panel
Dayj's truck has a modified 3-hole gauge cluster. No tach though. Scroll down toward the bottom of this thread.
https://67-72chevytrucks.com/vboard/...d.php?t=821945 |
Re: Dash panel
https://classicdash.com/product/1967...ck-dash-panel/
I know this isn't exactly what you are looking for, but may be worth checking out. |
Re: Dash panel
Another route you could take
If you’re going to put you gauges in the dash panel anyway, I’ve seen where guys will mount the aftermarket gauges in the stock holes, but you have to carefully cut them out for the larger cups. This way the stock spacing is already there. |
![]() Join Date: Mar 2015
Re: Dash panel
Stepsider;
I added a transmission temperature gauge to a cluster a long time ago. I was never really happy with the look but it functioned fine. It always looked like a add on. May have been better if I had changed them all? Using the correct diameter gauges is really important for "the look". Purchase the new bezel and then complete the first prototype using the old bezel. Undoubtedly you will find improvement you can incorporate in the design. |
![]() Join Date: Jun 2002
Re: Dash panel
I have a 3 hole cluster I'm going to put in my jimmy eventually. Not a great pic, but it does show it. I used gauges from a 65 chevelle and also a had to do a lot of work to make everything work together. I basically copied this from soon2blaze's build, here's a link. https://67-72chevytrucks.com/vboard/...6&postcount=85
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
The Older Generation
Re: Dash panel
There are a couple of threads on here where guys have used a glove box door and made their own gauge panel. Read through this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=261786 Most of the conversion work starts on page 2. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-01-2022 at 01:21 PM. |
Re: Dash panel
I notice on the two gauge panels that the four in one unit all gauges. Where that from ?
Re: Dash panel
The ones I posted were from a 65 chevelle with the sport package, not sure what dayj used but it looks similar.
Rg
#10 | |
Re: Dash panel
I have a couple of those from a '60's-'70's school bus. I mounted one in a '67 or '68 2 hole dash but never finished it. I will have to dig it out and look at it again. EDIT: I found a thread that I posted some info about it in also.... http://67-72chevytrucks.com/vboard/s...d.php?t=363858 Wow! That was a long time ago. No wonder I don't remember a lot about it... ![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-01-2022 at 05:17 PM. |
Re: Dash panel
Mine from my 68 project.
I used a stock bezel. I used Auto Meter 5" speedo and tach. 2 1/8" for gas, volt, oil and temp gauges. The 2 1/8" gauge between the speedo and tach is for turn signals and high beam lights. To make it work I took a 18 gauge piece of sheet metal and cut it to fit just inside the bezel edge. Hole sawed the gauge holes as needed. Cut gauge holes before you trim it to fit because the hole saw can catch and wreck the panel. Ask me how I know. Then after painting it with spray bomb wrinkle finish black paint to kind of match the stock bezel I epoxied glued it to the bezel. Worked great. See attached pic. |
