69 c-10 vin plate location
so i have a question. the vin plate on my truck was removed by the body shop to fix some rust that was around it. the vin plate has not been changed my question is what is the measurments for the location for the two plates that go in the door jam. i am asking you all this because the owner of the body shop that had my truck has passed away so now i am left answering questions and figuring out what was done. i want to state that this vin is the vin that goes with this truck so there is no shady stuff going on with it. i just need to put it back where it belongs. the truck was made in canada if that makes any diffrence. there is a gvw plate and a vin plate. any help would be welcomed
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
![]() Join Date: Nov 2022
Re: 69 c-10 vin plate location
Hmmm looks like no-one wants a piece of this action (Vin plate issues).
With that said, it is a 99.9% bet the body shop did not weld in the (4) rivet holes where the plates affix (2 top plate, 2 lower of course). So, just reach behind the B pillar with your hand and feel the push through nubs of the filler they used and there you go. Putty knife it off and use an angled pick to push it through the front. Good luck. Last edited by CKfan; 02-22-2024 at 10:57 PM. Reason: Correction I doubled the amount of holes |
#3 | |
![]() Join Date: Aug 2014
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
![]() Join Date: Mar 2011
let us know how you make out ....I have a 69 built in the USA if they are the same ill take measurements an pictures for you if needed
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Edited my post up top. Should have been 4 holes...2 and 2
Just checked my 1969 C 10 . It's 1" in from outside of door and 1" down from widest point of door bend . HTH
maybe this helps
