03-15-2021, 08:46 PM | #1 |
C10 CLUB Y QUE!
Frame
Is a 1963 suburban frame the same length as a long bed or short?
03-15-2021, 09:43 PM | #2 |
Re: Frame
I'm pretty sure you can find that info in the factory assembly manual. It has all the dimensions.
03-15-2021, 10:07 PM | #3 |
Re: Frame
The wheelbase is the same as a short bed truck, but the rear of the frame is longer than a short bed. It also has a different shape to work with the body mounts and rear bumper
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-16-2021, 12:15 AM | #4 | |
C10 CLUB Y QUE!
Re: Frame
Never mind now |
01-25-2022, 09:00 AM | #5 |
Re: Frame
Just jumping in here since my question is pertinent; in looking for a replacement brake line kit the short bed version will fit?
01-25-2022, 07:14 PM | #6 |
Re: Frame
The frames are the same with respect to original brake lines.
