Old 03-28-2022, 07:02 PM   #1
Charley7
Powersteering conversion issue
So i have a 1971 c10 2wd. I’m trying to convert it from manual steering to power steering. I’ve read the swap info section a few times and searched this forum. I have steering gear 7802644 and found I needed a 6131 pitman arm. The issue is that the inner tie rod hits the crossmember before I can get the pitman arm on. It does have wilwood drop spindles on it.
Thanks for any further info.
Charley.
Charley7 is offline   Reply With Quote
Old 03-29-2022, 05:48 PM   #2
SCOTI
SCOTI's Avatar
Re: Powersteering conversion issue
Charley.
This is common when the center-link/drag-link is flipped when reassembling. The inner TRE's should not make contact w/the center x-member throughout lock-to-lock turning travel.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-29-2022, 06:12 PM   #3
Charley7
I never even thought of that. I never installed the steering. The truck was purchased as a roller and was freshly assembled. Thanks.
Old 03-30-2022, 12:25 AM   #4
kwmech
Pics for verification
