Old 03-24-2019, 10:28 PM   #1
NewBayColony
NewBayColony's Avatar
Radio Delete Plate Clip Alternative
Has anyone come up with an alternative to the radio delete plate clips?
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 03-24-2019, 10:52 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Radio Delete Plate Clip Alternative
Rare earth magnets work like a charm.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-25-2019, 12:19 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Unless you have a compass on your dash.
Old 03-25-2019, 12:36 AM   #4
Sheepdip
Sheepdip's Avatar
Just thinking out loud here....Velcro?
Sheepdip is offline   Reply With Quote
Old 03-25-2019, 07:45 AM   #5
randy500
You can cut down a lower body side molding clip and use a nut and washer on the back.
randy500 is offline   Reply With Quote
Old 03-25-2019, 08:17 AM   #6
NewBayColony
I have magnets now and after awhile the plate moves, I thought about Velcro but I do like the molding clip idea. Thanks.
It must be easy to keep a steady course with that compass setup.
72 C20 292 3OTT
Old 03-25-2019, 08:36 AM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Radio Delete Plate Clip Alternative
Looking at this picture it should be very easy to make some clips for it. Cut 2 piece of sheet metal to fit as the original's do drill small holes in the center of each one and put a small screw in it. Place it in the right spot and take some washer that will fit the radio dial holes good and nut tighten it up your done.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-25-2019, 08:54 AM   #8
NewBayColony
[QUOTE=Andy4639;8494146]Looking at this picture it should be very easy to make some clips for it. Cut 2 piece of sheet metal to fit as the original's do drill small holes in the center of each one and put a small screw in it. Place it in the right spot and take some washer that will fit the radio dial holes good and nut tighten it up your done.
I LIKE it. Thanks
72 C20 292 3OTT
Old 03-25-2019, 10:22 AM   #9
leddzepp
Moderator
leddzepp's Avatar
Rare earth magnets are very strong, I’m using them on a delete plate now and it does not move at all. If you are using plain magnets they will not hold very well.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-25-2019, 10:37 AM   #10
NewBayColony
That's probably my problem.
Did you put them behind the dash or in-between the plate and the dash? Where did you get them? Thanks again!
72 C20 292 3OTT
Old 03-25-2019, 10:42 AM   #11
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Velcro works great.....
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 03-25-2019, 11:02 AM   #12
bill3rail
bill3rail's Avatar
Yes, I made some. Not that complicated, just took way too much time. The tools I needed to buy were about $50.00 and I'll never use them again!
Sorry about the image size, not sure how to adjust it.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 03-25-2019, 01:52 PM   #13
NewBayColony
[QUOTE=bill3rail;8494216]Yes, I made some. Not that complicated, just took way too much time. The tools I needed to buy were about $50.00 and I'll never use them again!
At least they came out nice. For what they go for, maybe you should make a bunch and pay off the tool.I wouldn't mind a couple of test pieces to evaluate. Just sayin...
72 C20 292 3OTT
Old 03-25-2019, 05:54 PM   #14
Leonard1
Leonard1's Avatar
Leonard1 is offline   Reply With Quote
Old 03-25-2019, 05:55 PM   #15
bill3rail
bill3rail's Avatar
[quote=NewBayColony;8494340]
I would need to buy a bunch of material and another expensive tool and set up a production run in my garage. Too much work for very little income. Realistically, how much could I sell them for? And how many would actually sell? Probably not worth the time. If I still worked in the machine shop, I could run a different operation each day and knock them out over a few weeks during lunch breaks and between automatic machining operations.
Old 03-25-2019, 06:52 PM   #16
'68OrangeSunshine
You do have to allow for windage and current drift, though. Also the Magnetic Poles are shifting.
Old 03-25-2019, 08:45 PM   #17
NewBayColony
I'm old. I have problems with the current drift, the earlier drift, the later drift. Apparently, I have problems because I just drift off. Don't even get me started on my windage problem.
As far as Command Strips, I'm married, I'm subject to enough commands.
72 C20 292 3OTT
Old 03-25-2019, 08:46 PM   #18
NewBayColony
[quote=bill3rail;8494471]
OK, but yours are sooo nice.
72 C20 292 3OTT
Old 03-25-2019, 09:01 PM   #19
bill3rail
bill3rail's Avatar
[quote=NewBayColony;8494593]
Want to buy a hundred or two? No? That is what I thought. J/K
Very small market so it is not worth the cost.
Old 03-25-2019, 09:03 PM   #20
NewBayColony
[quote=bill3rail;8494611]
I do want to buy two.
(trying to be funny)
72 C20 292 3OTT
Old 03-25-2019, 09:52 PM   #21
bill3rail
bill3rail's Avatar
[quote=NewBayColony;8494613]
Funny is good, Funny is good! [Good Morning Vietnam Scene]
BIll
Old 03-27-2019, 09:48 AM   #22
67chevemall
67chevemall's Avatar
I agree they will hold my delete plate.
I use them to hold my licence plates on so no holes in the roll pans.
They keep my doors closed in the house and magnet fishing is a blast.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 10-18-2019, 11:53 PM   #23
Sheepdip
Sheepdip's Avatar
I have been searching for a radio delete plate for a while, there's not a real shortage of them so to speak but I refuse to pay $125 plus $10 to ship off of ebay, and found a local guy on Craigslist that wanted $80 and I refuse to pay that also... so I made my own.
Not quite an original but still looks nice, sanitary and acceptable to me.
Old 10-19-2019, 01:29 AM   #24
3757chevy
3757chevy's Avatar
I used these body molding clips on my delete plate. Just get a fender washer to cover the hole from the rear.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 10-19-2019, 08:22 AM   #25
68panelman
68panelman's Avatar
Bingo^^^
68panelman is offline   Reply With Quote
