![]() Join Date: Jul 2015
1972 k10 battery cables help
Does anyone know what length both battery cables are for a 72 k10 with a 350 and A/C. Looking to route them as they were from the factory and any brands/places to get a good quality cable. Also which side of the battery is the positive supposed to be on? Passenger side?
![]() Join Date: Dec 2013
Re: 1972 k10 battery cables help
batterycablesusa.com , Order or build your own , Nice stuff .
![]() https://67-72chevytrucks.com/vboard/...d.php?t=833631
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Carpe manana
![]() ![]() Join Date: Dec 2010
Roger Koop (member here) was selling a decent set of repro battery cables with the correct side post connections. A search or PM should turn up that information. Positive is on the driver side of the battery if I recall.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
72 C10 lwb fleetside -stock 350/350 combo |
Does anyone know the lengths of both cables?
+ 44" and - 25"
![]() Join Date: Jun 2018
Opened up the Roger Koop repro's..........27" & 44" is what I got.
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
1972 350 with A/C
Marking on 44" cable = 6093TLP Marking on 27" cable = 4784TAL I can't measure the wire gauge, but based on my micrometer measuring the OVERALL thickness of the insulation & wire (.428) I'd say this is a 2 gauge. Hope that helps...........
How long is the aux wire on the positive cable? Any idea on the gauge of it? Does the ground wire have a extra wire also? If so how long is it ect.
Both have a secondary wires measuring .178
+ wire is 18" long - wire is 17" long I didn't state earlier, but this is for the factory side mount battery, NOT the top mount. Not sure how much difference it would make, just pointing it out.
Thanks for taking the time to answer my questions... You gave me all the info I needed.
