Old 06-08-2022, 01:39 PM   #1
Sloan66
Good lower Rht front fender patch!
Read several post about having to modify the rht front fender patch. I picked one up from AMD and it was very close fit! I drilled out the spot weld on the very front portion and just had to move it slightly to line up.
Sloan66 is offline   Reply With Quote
Old 06-08-2022, 03:41 PM   #2
tommy3horse
tommy3horse's Avatar
Re: Good lower Rht front fender patch!
Nice work there!
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline   Reply With Quote
Old 06-09-2022, 09:40 PM   #3
Roostre
Roostre's Avatar
Looks good! And very similar to mine, except I had to cut mine apart even more than just the spot welds to get it to fit!
Roostre is offline   Reply With Quote
Old 06-10-2022, 09:32 AM   #4
SCOTI
SCOTI's Avatar
I had to do the same as what appears in your image. Cut it down the middle. Fit the rear section up so the body line & wheel open features align. Fit the front section up so it fits best. The make a filler piece for the gap between the F & R sections.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-11-2022, 06:02 PM   #5
Peanut74
Glad you got a good patch panel. Mine was a challenge to get it to fit right. Had to cut it both vertically and horizontally to make it fit right.
Nice job and looks good.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
