Old 12-13-2021, 11:51 AM   #1
dagnabbitt
dagnabbitt's Avatar
Spacers for Centre Caps?
I picked up this 72 GMC 2500 with a 6.2 diesel during the summer: I really like this truck. Fuel economy, combined with power steering, power brakes, shoulder harnesses... and tilt (!) makes it kind of a luxury vehicle to me, compared to my other 67-72s.
When I got the truck, it had these crazy wheels on it which I have to admit did grow on me over time... but they just are not "me", and they had to go. I had some rough 2010 Suburban wheels which I painted up. I got conversion lug nuts, modern centre caps, and installed them. The truck rides much nicer now since these are 17's and the other rims were 20s, and the truck is slightly less of an eyesore. I have some plain steel wheels I am getting sandblasted right now, so these wheels will not be the last word on the subject but I think they are an improvement. I can also now sell those crazy 20s and put a little money in my pocket, I wonder what they are worth.
The issue I have now is that the rear axle is a floater so the caps will not fit over the hub. I have heard of people double nutting the rear wheels: taking a stock lug nut, then putting a conversion lug nut on top to create a spacer. I am just checking to see if that is what most people who have made this change recommend, or if there is a better way to achieve the look that I want.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 12-15-2021, 09:52 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Spacers for Centre Caps?
I remember reading that the dually caps fit the rear. The center is big enough to fit over the hub.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-15-2021, 10:59 AM   #3
dagnabbitt
dagnabbitt's Avatar
Thanks, I hope I can find some, I would like to try that.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-16-2021, 07:19 AM   #4
Ol Blue K20
No problem, keep us updated
Dale
Old 12-17-2021, 06:26 AM   #5
Why not use wheel spacers?
Old 12-17-2021, 05:45 PM   #6
dagnabbitt
dagnabbitt's Avatar
That is an interesting option, too. I was just thinking that the wheels look a little too "tucked in" at the rear, so that might kill two birds with one stone.
I will post what I end up deciding. If anyone has recommendations for wheel spacers let me know.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-25-2022, 12:23 PM   #7
dagnabbitt
dagnabbitt's Avatar
So I decided that the Yukon wheels and tires that I have posted on the truck will look better on my 2010 Yukon... and that what the green machine needs is steelies.
Still waffling on that rear hub cover, though. I am hesitant to use wheel spacers, and I am also not sure how a dually hub cover would look in the back. I have found these online and they might suit the truck and cover the hub properly.
Would I put the "rear" cover on all four wheels so they match? Although there are lots of threads on the conversion lug nuts, I can't find much on this particular issue since most of these conversions are on 1/2 tons. It would be great to have some pics as a guide if someone has done before.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-25-2022, 02:35 PM   #8
I think www.lugnutking with have the SAE duplex lug nuts. I know the lug pattern went to 170mm (I think?) from 6.5" on 8-lugs. The wheels are close but do not interchange. Not sure it's a problem with center caps or not. I know it's close. Maybe someone has experience with this
Old 01-25-2022, 05:39 PM   #9
SCOTI
SCOTI's Avatar
Ditto on this info. Verify the different pattern caps will work for what you want to do. Try finding someone you might know that has the later caps to test fit (co-worker/neighbor/board member/random hot-rod or repair shop) unless where ever you purchase them from allows returns.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 06-27-2022, 11:59 PM   #10
dagnabbitt
dagnabbitt's Avatar
Thank you to those who pointed me in the right direction with my question, I relied upon the advice I received in this thread and found what worked.
Although I considered spacers, I decided to just be simple and get conversion lug nuts and dually caps for the rear: they fit perfectly of course. Thanks Ol Blue and Special K for those suggestions
The ones I used were the early, black OBS style: the fronts are repopped but the rears are OEMs that you might be lucky enough to find in a junkyard. I like them especially on my satin black steel rims.
Also for future searchers of this topic, Special K is right, they changed the 8 lug bolt pattern when the wheel went from 16" to 17": they will not fit. I tried one and it was close but a no go.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-28-2022, 12:07 AM   #11
bwl101
bwl101's Avatar
That looks good and loving the XTs as well! I have enjoyed them since they've been on mine!
'72 C10 Long Bed Stepside
Putting my Grandfather's truck back on the road:
http://www.67-72chevytrucks.com/vboa...d.php?t=829659
bwl101 is offline   Reply With Quote
Old 06-28-2022, 12:45 AM   #12
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Those wheels look way better. Good call.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 06-28-2022, 01:37 AM   #13
RichardJ
I rejected the idea of wheel spacers, because you loose the Hub-Centric feature with the spacers that are available.
Instead, I made a spacer for the rear Hummer cap.
I found a good set of GMC caps which fit fine on the front, but have yet to fabricate new spacers for the rear.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 06-28-2022, 07:11 AM   #14
That looks great, Dave. So, it's when the wheels went to 17" that the lug pattern changed? Good to know. I suggested wheel spacers as a solution that came to mind. But to be honest, I'm not big on those myself. I have never used them before. The larger center cap on rear looks right. Same as front would have looked good as well, for sure. But GM did that where they had to and you did what GM would have done. Also just used to seeing the full-floating rear hub protrude anyway. In the end, it probably won't stand out to most people anyway.
I put black D-hole wheels on a '91 V2500 Suburban and used the same black center caps 9as front) to trim them out w/o adding chrome. I used a hole saw and cut out the center for the front
Old 06-28-2022, 10:01 AM   #15
dagnabbitt
dagnabbitt's Avatar
Looking at what I posted and just want to clarify that I was incorrect, it is not the 17" rim: it was a year change.
Starting in 2011 the pattern for 8 lug Chevrolet products went from 8 x 165.1mm, to 8 x 180mm.
Its a pretty subtle change, so subtle in fact that they really look like they would fit.
I monkeyed around with one for probably 15 minutes before realizing the difference. It was confusing to me because a change like that would seem to be something you do during a model change, or a clean sheet of paper design change. Instead, my 2010 Yukon XL is pretty much indistinguishable from a 2011, with the exception of the lugnuts being 15.1mm further apart.
Learn something new everyday with Chevys.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-28-2022, 10:57 AM   #16
Ol Blue K20
They look great! I'm glad it worked out for you.
Dale
Old 07-03-2022, 03:20 PM   #17
northerngmc
northerngmc's Avatar
I ran into a simliar problem with the Ion 18x9 wheels on my 68 C20.
I built a spacer to go between the wheel and the cap out of a toilet flange.
Then I decided the wheels were too black and plasti dip coloured the letters on the centre cap and added a pinstrip.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 07-03-2022, 05:40 PM   #18
HalfBrit
Nice results on the wheels/centers! As a side note, I picked up a set of billet aluminum hub-centric spacers for my '70 C10 2WD. I have 17X8's and, as mentioned earlier, had an issue with the rear wheels sitting further in the fender lip than the fronts. I just used 1/2" plain spacers (no studs) to tighten up the fitment. I provided all the measurements required to ensure a perfect fit from axle flange to wheel. Very happy with the quality. Here's a link for anyone considering that option. https://www.uswheeladapters.com/
HalfBrit is offline   Reply With Quote
