Old 07-07-2022, 07:07 PM   #1
twoskies
twoskies's Avatar
Fixable ?
Got a hood thats in pretty good shape as far as rust, but there is a crease on the passenger side front
i could probably build it up with weld and grind down
also has a place in very back in middle that has been pushed down, im thinking of adding a third brace between the original two , put a piece of foam in there to keep the shape
am looking for ideas
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 07-07-2022, 07:22 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Fixable ?
That doesn't look too bad. You probably know they make and sell both Upper and lower front sections of the hood. I had mine replaced.
Old 07-07-2022, 10:16 PM   #3
twoskies
twoskies's Avatar
Re: Fixable ?
Yes, i do know they sell the upper and lower, trying not to have to deal with hundreds of spot welds, but i will, lol
if need be
Old 07-08-2022, 12:40 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Fixable ?
Why not just use a good body filler for that small ding.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-08-2022, 03:35 PM   #5
val1gonzales
Re: Fixable ?
Easy fix. Using a grinder cutting wheel cut out a slot, the width of blade, along the red line. Then use a chisel or screw driver to work the metal back up and open to the seam. Once you have the seam straight weld the slit back.
val1gonzales is offline   Reply With Quote
Old 07-08-2022, 04:23 PM   #6
LostMy65
LostMy65's Avatar
Re: Fixable ?
Great solution.
Old 07-08-2022, 05:08 PM   #7
twoskies
twoskies's Avatar
Re: Fixable ?
nice, think ill give it a try, bottom has slight dent also, not as bad as top
