Old 02-24-2022, 11:40 PM   #1
rustyrodknocker
Daily drive lunch box locker
I need to replace the spider gears in my 8.5 but I was looking at maybe doing a locker instead. Specifically the Spartan lunch box style. This is for a daily driver. I don't go offroading. I go out in the woods in some mud and snow but I stay on a developed road unless of course I slide off. I do to a motorcycle trailer and car trailers sometimes and travel several hundred miles from home out in the high desert. So dependability is a must. As is driveability.
What experience do you guys have with this type of unit?
I could also go the posi carrier route also. Little more work little more money but
Better driveability. But I have also heard trucks are hard on them and wear out the clutches.
This is a stock k1500
rustyrodknocker is offline   Reply With Quote
Old 02-25-2022, 03:28 AM   #2
Richard
Re: Daily drive lunch box locker
A lunch box locker can be more harsh and noisy than a detroit or grizzly locker. Those type of lockers can be touchy on the street. Zero need for a LBL on the street. Low cost is only benefit IMO. I would use a torsen type diff like the Tru-trac if in your shoes. Strong, smooth and reliable, no clutches to wear out. Only drawback I have seen is it can act like an open diif when lifting a wheel. Applying brakes can help the problem but it does not seem like that would be a problem for you.
Richard
Old 02-25-2022, 08:35 AM   #3
mongocanfly
mongocanfly's Avatar
Agree with Richard, im thinking you wont like it, buddy of mine tried one once, he said it was awful on the road
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-25-2022, 07:42 PM   #4
rustyrodknocker
Sounds like a new set of spider gears are in order. I'm not going to put too much into this truck. Thanks for the input!
Old 02-25-2022, 10:26 PM   #5
Mike C
Mike C's Avatar
I would put a clutch type limited slip in it. The 30 spline 8.5” Yukon can be had for just about $300 if you shop around.
I believe everything should have an LSD or traction aid of some type. I run a Powertrax NoSlip in my CJ-5, and for a lunchbox it is surprisingly nice on the street, but they are expensive… I got two for the price of one so both ends of my Jeep are locked for 1/2 price. But I would NOT run a LockRight or a Spartan on the street. They are clunky and ratchety on the asphalt but near seamless off-road.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-27-2022, 12:24 PM   #6
duallyjams
duallyjams's Avatar
Had a K20 daily driver with 35's and a locker for 4yrs in all types of weather ( rain,snow and ice ) with no problems. It did make a clicking sound making tight turns, never had any loud clunking or any type of jerking with it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-27-2022, 02:32 PM   #7
BASE
BASE's Avatar
People with heavier trucks seem to get along better with them. I had one in a ‘75 K20 up in AK for a few years and never really even noticed it. Guys with Jeeps seem to end up pulling them right back out and going with LSD’s or air lockers. Now that I’m thinking about it, maybe the shorter wheelbase makes it worse too. I dunno, just seems like a trend I’ve seen over the years.
BASE is offline   Reply With Quote
Old 08-16-2022, 07:32 PM   #8
Backpayne
Did you ever happen to install a lunchbox locker? I'm looking at them for my '66 4x4 with 35 inch tires.
Backpayne is offline   Reply With Quote
