08-29-2022, 11:26 PM | #1 |
Air over leaf set ups.
Please let's not start with why it's a bad idea. I know most of them.
Well I removed my old leafs, and put in some rebuilt ones I did. I re-arched them to match after building a jig for my press. Well technically they after better then my old ones. They only sag 1.5" to the passenger side not the 2.5" my factory one's did. Winning right. Well I need the truck lifted back up not just sagging all the time till I can afford new leaf springs made to my specs. Factory 56" are too stiff for a rcsb. The springs I want are $1500. Or I have to move a bunch of stuff around to clear a pan hard bar for a 4 link, and just air bag the whole thing. Currently I am financially deep in what was supposed to be a engine swap into the truck, but turned into. I will just fuel inject it for the time being till when my hand heals up again. Plus my Durango has been putting a hurt me real bad too. So it's needs to be on the cheap till things line up again for me, and Abe Lincoln is crying from the penny pinching. I already have the bags, and line to fab up helper air bags. The bags are Slam SS7's I believe or 8's. Can't remember right now. I know the biggest reason air over leaf is bad is most people remove all the leafs except the main. Which cracks from bending the wrong way, and the lack of support. What if i ran the 2 big leafs, and the bottom leaf. Or just the main leaf, and the bottom leaf. Is there a decent way to pull this off for a few months |
08-30-2022, 10:20 AM | #2 | |
Re: Air over leaf set ups.
You can set-it up any way you need for the ride height you're targeting.
08-30-2022, 12:25 PM | #3 |
The ride height is fine on the driver side. With a slightly worn leaf which still has a good bit of curve.
I don't want to do it, but I need 2 vehicles. So I can leave the truck in back up, and only drive it when I need to. Or a couple times a month to keep it lubricated. So my though is if I run the main leaf, and atleast the bottom. It stops the main from taking a beating on the small foot print of the mount. Is that pretty much true in concept. |
08-30-2022, 01:34 PM | #4 | |
08-30-2022, 04:18 PM | #5 |
Should be fine to add a bag over the leaf. It would just be like an overload airbag which is common for hauling weight or towing trailers. My daily has them and has for 5+ years.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
09-06-2022, 11:04 PM | #6 |
I installed "overload" bags from superlift or whatever that common company that makes kits for that purpose. I did not like the idea of the bag sitting on /clamping to the spring (the way the kit was designed) so I cut the brackets & moved some things a bit & have them sitting directly on the axle housing (I have a flipped rear) & it has worked great for years. I keep just a few pounds in them when the bed is empty & air them up to maintain the same ride height as it would be empty when using "as a truck". I removed the heavy "overload" spring from the pack long ago so I have 4 leaves now. Lorne
