Old 09-19-2022, 07:53 PM   #1
72 Cheyenne K20
12 Bolt Rear End ID Help Please
Hi All,
Can anyone please give me gear ration info on my 12 bolt rear end. Have a 1980 Jimmy and the stamped ID from the top of the right tube is:
T A M 058W02
From what I was able to find out: the 058 is February 27th, the W is Warren & the 02 is the Shift. Please correct me if I'm wrong. I just can't seem to find the gear ratio anywhere!
Thanks, Scott
72 Cheyenne K20 is offline   Reply With Quote
Old 09-20-2022, 09:11 AM   #2
MJN
MJN's Avatar
Re: 12 Bolt Rear End ID Help Please
TAM is the ratio code, which is 2.73
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-20-2022, 10:43 AM   #3
72 Cheyenne K20
Thank you very much for that info MJN!! 2.73 ratio, that’s why she’s a little sluggish off the line. Good highway gears though!
Scott
Old 09-20-2022, 11:19 AM   #4
mongocanfly
mongocanfly's Avatar
My 86 had 2.73s.. with my manual L+3spd, I had to use L to get rolling.. would almost choke down starting in 1st
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-20-2022, 05:55 PM   #5
72 Cheyenne K20
I've been on the other end of the ratio spectrum too. Had a 71 K20 I bought from a guy in Montana. 350 & a 4sp with I believe 4.56's. I was scared to get over 50 mph because the engine just screamed. I'd much rather be on this end!
I do have one more question. The front differential is a GM 10 Bolt. Any stamping I can look for on that? I did look for a ratio tag mounted to the cover, but no such luck.
Scott
Old 09-20-2022, 07:02 PM   #6
kwmech
Should be thee same ratio as the front--in fact it better be
kwmech is online now   Reply With Quote
Old 09-20-2022, 08:50 PM   #7
72 Cheyenne K20
I'm positive they are the same ratio, tore up some snow last winter. I just wanted to know if there was a ratio code or a date stamp on the front axle & where that would be located.
Thanks Scott
Old 09-20-2022, 08:53 PM   #8
MJN
MJN's Avatar
front axles are stamped on the tube, similar to the rear axle. Heres a screenshot out of the 1979-1984 parts catalog, you can download a pdf copy from board member Hatzie and look up the code on yours.
http://67-72chevytrucks.com/vboard/s...d.php?t=545416
'17 GMC Yukon XL
VCCA member #58596
Old 09-20-2022, 09:19 PM   #9
72 Cheyenne K20
Well that's about the best piece of info I've received in a long time MJN. Downloaded and now able to not feel stoopid! I'll find time to dig through the gunk tomorrow and find the code.
I have to now, looked at 1980 front axle ratios available and 2.73 was not an option from what the book says!
