10-05-2022, 08:18 PM | #1 |
Cargo panel material
What are guys using to make up your cargo panels with? Built the bed up with the tops of old rusted out doors, so stock material want work because there gonna be taller.
Got any idears, Thanxs
Things happen for a reason! |
10-06-2022, 12:33 PM | #2 |
Re: Cargo panel material
PVC board 4 x 8 sheet about $100 for 1/2"...also comes 3/8" + 3/4" and it's paintable.
10-06-2022, 02:35 PM | #3 | |
Thanxs
10-06-2022, 03:21 PM | #4 |
Possibly at Home depot, or other building supply, Azek is a name brand I used smooth on both sides, photos on post 21 on my build page.
10-07-2022, 07:07 AM | #5 |
I used textured black ABS plastic sheet....3/16" thick with push-on vinyl edge trim and aluminum "J" channel at the top
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-07-2022, 09:39 AM | #6 | |
Thanxs
10-07-2022, 10:37 AM | #7 | |
I also have a .pdf file of the dimensions if you need it
10-08-2022, 09:11 AM | #8 |
I was looking to use HDPE - 1'8" thick. I believe 1 sheet (4' x 8') can be cut down and will cover both sides - haven't measured to be sure though. Waterproof, available in white/black, etc.
Link to Menards product - here Let us know which route you go...need to do this in the future as well. |
10-08-2022, 08:50 PM | #9 |
The only thing with my build is I've built the bed up so its probably 3 or 4 inches taller than a stock blazer. I like the idear of 3/16 thickness and also in red. Is this out there guy's?
Thanxs fr any direction in this product.
10-10-2022, 08:54 AM | #10 |
A1971Blazer - can you PM me the PDF - will be doing this at some point as well
thanks
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
10-10-2022, 10:45 AM | #11 | |
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
10-11-2022, 09:01 PM | #12 |
Equal opportunity joke ofender
Komatex (PVC board) can be had in 1/8" or 1/4" thickness and comes in red. If you have a sign company local to you they could order in a 4x8 sheet for you
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
11-06-2022, 05:48 PM | #13 | |
I do have a sign company near me and will look into that.
