11-15-2022, 04:39 AM | #1 |
2001 Silverado 1500: volt gage fluctuates
I will start with an apology in case I am not posting in the right forum.
My 2001 Silverado's volt gage fluctuates from 14 to 16 volts when the engine is idling or when I am driving the truck. I replaced the original alternator with a new one just because the old one had a lot of use on a truck that already had around 111,000 miles. The new alternator worked wit a hitch for over two years until the volt gage pointer started moving or fluctuating as explained above. I assumed that either the voltage regulator (or the rectifier) was malfunctioning, so I replaced the alternator with a new one since it is under a lifetime warranty, but the problem continues, even with this last brand new alternator. When I check the alternator's output to the battery with a Fluke multimeter, or with a digital battery/alternator tester I have, the alternator is working perfectly at 13.2 VDC base charging voltage, and a maximum of 14.5 (no fluctuations whatsoever on the meter and tester, just the volt gage in the dash). I assume that the voltage regulator in inside the alternator, and that the two new alternators aren't causing the problem. Do you have any idea what could be causing the volt gage to fluctuate like that? The only plug on the alternator is located right on top, and has two wires that run toward the trucks cab. I imagine that these two wires lead to the volt gage. I have checked the plug contacts, and everything seems to be clean and solid, but I haven't been able to trace the wires all the way to the gage. Thanks in advance!
2001 Silverado 1500, with a 325 Vortex motor, 4x4, with over 213,000 miles and countless hours of idling. Last edited by RayInAlaska; 11-15-2022 at 04:46 AM. |
11-16-2022, 10:17 AM | #2 |
Re: 2001 Silverado 1500: volt gage fluctuates
odd are it's the gauge (stepper) motor. They do fail and or get sporadic, usually it's the tach or speedo put all of them are known to have issues since it's the same motor. There's companies online that will refurb your dash or you can do it your self. There's lots of how-to info online and the motors are cheap enough on ebay or amazon. If you have a scan tool that can monitor some data like voltage that will tell you what the ECU and seeing and if it's staying steady and the gauge is moving around that's a pretty solid confirmation your gauge motor is on it's way out
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
11-19-2022, 04:38 AM | #3 | |
Thanks again!
2001 Silverado 1500, with a 325 Vortex motor, 4x4, with over 213,000 miles and countless hours of idling. |
11-19-2022, 05:58 PM | #4 |
Moderator
The instrument clusters have an onboard surface mount DC-DC converter circuit and a raft of surface mount pull up and pull down resistors. The solder joints tend to fracture from thermal cycling.
The stepper motor problems are in the 2003-2007 clusters and some of the 2007-2014 clusters as well. The 1999-2001 clusters used board mounted air core meter movements like the T400 clusters. These are a bit more reliable than the 2003-07 stepper motor gauges. I'd send the cluster out to be repaired. United Radio has a good reputation.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 11-20-2022 at 01:29 PM. |
