Old 02-17-2023, 08:36 AM   #1
Nevada51
Six cylinder to V8 swap and the three speed manual trans
I’m exploring the possibility of swapping out my stock six cylinder block for a small block V8 in my ‘64 C10. A small block seems like a relatively easy, budget conscious swap. Two or three questions:
1) can I use my stock three on the tree manual trans, and if so, is it a matter of having the right bellhousing and it should all bolt up fine? I assume a new clutch would also be required?
2) were the brakes the same in the six vs the v8? FWIW my ‘64 is a stock, base model if that makes any difference.
Thanks in advance.
Cam
Nevada51 is offline   Reply With Quote
