Old 01-27-2023, 01:39 PM   #1
HotRodRancher
Heat Riser Valve
I'm returning a 1972 C20 truck with its original 350 back to stock using the original cast iron intake and quadrajet carb. I will leave the crossover passages in the intake open as they were were originally. From the factory when new did the passenger side exhaust use a heat riser valve between the exhaust manifold and exhaust pipe?
TIA
HotRodRancher is offline   Reply With Quote
Old 01-27-2023, 03:17 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hear Riser Valve
TIA
On my '72 K20, yes. Probably on your C20 too.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 01-27-2023, 05:40 PM   #3
54blackhornet
54blackhornet's Avatar
My 71 C/20 has no valve ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-27-2023, 07:10 PM   #4
FirstOwner69
FirstOwner69's Avatar
My'69 C/20 with a 350 came from the factory with the heat riser on the driver's side.
Best pic I can find.
Jim
FirstOwner69 is offline   Reply With Quote
Old 01-27-2023, 08:22 PM   #5
Casper42
Casper42's Avatar
my 350 engine had been removed, as a lot in the Pacific Northwest trucks had, but all the historical or current pics I have seen show it on the driver's side. memory serves me that the big block had it on the passenger side, and not sure about other engines. I "believe" all 350's had it on the driver side. Any easy tell-tale was how the stock aircleaner was installed. if the intake neck was on the driver side then the heat riser and stove pipe would follow suit. Perhaps do you still have the factory label on the aircleaner? that might help tell you how yours was.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 01-27-2023, 08:59 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Could be possible that 2WD trucks had it on the drivers side, and 4WD was on the passenger side?
- Mike -
RIP El Jay
Old 01-27-2023, 10:02 PM   #7
Johnl48
My 70 350 4x4 had it on the passenger side. Took it off when I put the fuel injection on
