Old 06-06-2023, 09:37 AM   #1
blazer2007
why is my master cyl. doing this
My master cylinder is weeping slowly from the fr. resorvoir to the back one. Is manual brake setup with drum/disc setup on a 80,s truck. The old one did this so I thought there was something wrong so I replaced it with a new one and this one is doing it too. Where is my problem ?
blazer2007 is offline   Reply With Quote
Old 06-06-2023, 09:49 AM   #2
mongocanfly
mongocanfly's Avatar
Re: why is my master cyl. doing this
I'm not sure I follow what your seeing....how can you tell?..,both sides should be full
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-06-2023, 10:16 AM   #3
blazer2007
the fr. fills up the rear one and then it leaks. This takes about about 3 weeks then I notice a spongy pedal and I then take a turkey baster and take some fluid out from the rear and put back in the fr. reservoir . The rear reservoir is full to the top and of course it leaks when I pull the lid off at this point. The pedal is now fine at this point
Old 06-06-2023, 11:31 AM   #4
mongocanfly
Ok I understand what your saying now
There is a seal between the reservoirs..but 2 masters doing the same thing makes me wonder if the issue lies elsewhere.. I'm wondering if your proportioning valve could be transferring fluid to the wrong side..
Might be worth swapping it out
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-06-2023, 06:10 PM   #5
blazer2007
Ok I will have alook. At least it,s a starting point. Thanks
Old 06-06-2023, 07:49 PM   #6
geezer#99
geezer#99's Avatar
Is this truck converted from power to manual with the booster removed?
geezer#99 is online now   Reply With Quote
Old 06-07-2023, 09:00 AM   #7
blazer2007
no
Old 06-07-2023, 09:16 AM   #8
geezer#99
geezer#99's Avatar
So it’s stock then.
I was thinking pedal ratio might be the difference.
Does your brake pedal have two holes in it where the brake rod attaches to it.
