Old 08-13-2015, 09:33 PM   #1
Lugnutz65
Lugnutz65's Avatar
DIY 3 Point Seat Belt Installation 1960-66 Cab
Here's a DIY I made showing my 1965 C10 seat belt installation. I am not as familiar with the 1960-63 cabs, but it chould be the same.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-13-2015, 09:34 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: DIY 3 Point Seat Belt Installation 1960-66 Cab
More pics
Old 08-13-2015, 09:37 PM   #3
Lugnutz65
Lugnutz65's Avatar
More
Old 08-13-2015, 09:41 PM   #4
Lugnutz65
Lugnutz65's Avatar
more
Old 08-13-2015, 09:45 PM   #5
Lugnutz65
Lugnutz65's Avatar
another
Old 08-13-2015, 09:47 PM   #6
Lugnutz65
Lugnutz65's Avatar
Some more pics
Old 08-13-2015, 09:48 PM   #7
Lugnutz65
Lugnutz65's Avatar
another set
Old 08-13-2015, 10:06 PM   #8
Lugnutz65
Lugnutz65's Avatar
Several more
Old 08-13-2015, 10:07 PM   #9
Lugnutz65
Lugnutz65's Avatar
Last two pics
Old 08-13-2015, 10:25 PM   #10
AngryPirate
AngryPirate's Avatar
Great job and thanks for sharing. This is going to be super handy when I do mine.
Could I ask where you got the seat belts? I like the look of them.
Thanks!
Scott
AngryPirate is offline   Reply With Quote
Old 08-13-2015, 10:34 PM   #11
Lugnutz65
Lugnutz65's Avatar
Thanks!
Scott
I got the belts from Seatbeltplanet.com. They are the Lift Latch 140 inch with 20 inch adjustable buckle. The all metal lift latch buckle can get very hot if you live in a hot climate so choose the buckle mechanism that fits your needs. My seat is all the way back and the buckle end belt is barely long enough. Adjust the behind the seat anchor location a little more forward if needed. I am very satisfied with the quality of the belts and mechanism. They also have pre-made anchors that will do the same thing I did when I welded the nut to the washer. The belts do NOT come with any anchors kits so be sure you order that stuff too.
Old 08-14-2015, 12:13 AM   #12
DaddyOh
DaddyOh's Avatar
Lugz, do the 140" provide enough 'slack' to work if the bench seat was slid all the way forward? Basically, is it enough for each extreme in seat position... nice write up.
DaddyOh is offline   Reply With Quote
Old 08-14-2015, 12:43 AM   #13
Lugnutz65
Lugnutz65's Avatar
Yes. The 140" is plenty long enough.
Old 08-14-2015, 09:50 AM   #14
65chevysub
65chevysub's Avatar
What about us Suburban and Panel owners that want 3 pt belts? Same mounting? Our floor is a little different on the passenger side.
65chevysub is offline   Reply With Quote
Old 08-14-2015, 10:04 AM   #15
Lugnutz65
Lugnutz65's Avatar
I have no experience with the Panel trucks and Burbs. So I can't offer help there. If anyone has done this install in a Burb or Panel I would welcome their input with photos to explain.
Old 08-14-2015, 10:35 AM   #16
Grizz1963
Grizz1963's Avatar
Read through this on your blog and to be honest.........
I will be fitting some of these to my truck. Just need to find the right donor pieces.
Thank you for sharing Jay.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 08-14-2015, 11:03 AM   #17
pestwagon
excellent thread. Should be a "Sticky"
pestwagon is offline   Reply With Quote
Old 08-14-2015, 12:10 PM   #18
DaddyOh
DaddyOh's Avatar
Thanks... also, on the 20" stationary strap, will it still stay located on the seat when the bench is slid to furthest forward position? Hopefully that makes sense
Old 08-14-2015, 12:18 PM   #19
Lugnutz65
Lugnutz65's Avatar
No, I don't think the 20" side is long enough if the seat is all the way forward. If that is a concern then the only option would be to move the floor mount location forward or have them make that belt piece longer by 8-12". Too long would be easier to deal with than too short. They make an extension piece for the shoulder anchor and if you call them, they might suggest a similar extension piece for the floor mounted belt. So there are options to play with.
Old 08-14-2015, 12:43 PM   #20
DaddyOh
DaddyOh's Avatar
Thanks, gave them a call since I need a seatbelt to accommodate a 6 foot as well as 5 foot person...was concerned about the stationary side of the belt falling into crease of seat when the wife is driving. The solution: don't let the wife drive the truck.
When installing the stationary belt, allow 4-6" of 'lay' on the bench seat from the crease (in the furthest back position)... this should allow enough adjustment for various height people. If the seat can be adjusted beyond that (forward), a custom stationary part can be ordered. If using a GM style buckle, the length is non-adjustable. If using a lift-latch, you can adjust the length of stationary side.
The key point on the stationary side is that when latched, the buckle sits by the hip area. If the stationary side is too long, it may latch more towards the center of the body. If this occurs, it can make the shoulder strap non-operable and the occupant can slide out of belt. If the stationary strap needs to be adjustable, only certain styles of latches can be used.
Thanks again
Old 08-14-2015, 02:39 PM   #21
Lugnutz65
Lugnutz65's Avatar
Thanks again
Yes, the 6" of "lay" on the bench seat is ideal. However, the latch style buckle is adjustable. Therefore, if you custom ordered a 32" belt instead of their standard 20" belt, you could adjust the buckle end to the exact right position every time regardless of the seat position. The push button buckle style is not adjustable. I wish I had an extra 12" of belt on my buckle end. Right now I'm right at the limit. The photo below has the passenger and driver buckle belt adjusted to the longest position and my seat is all the way back. (I have the center buckle adjusted short so it doesn't flop around. )
Old 08-14-2015, 02:40 PM   #22
Clyde65
Clyde65's Avatar
Very good write up Lugnutz65! most helpful!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is online now   Reply With Quote
Old 08-14-2015, 05:18 PM   #23
SS317
SS317's Avatar
That's pretty cool. Well done.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 08-14-2015, 09:50 PM   #24
duallyjams
duallyjams's Avatar
awesome contribution
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-15-2015, 03:23 PM   #25
Ta2Don
Ta2Don's Avatar
Awesome write-up... Bookmarked...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
